Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sony Vaio PCG-71C11L Troubleshooting
Audio Distortion
You have trouble listening to sounds on your computer.
Blown Speakers/Mic
Test audio through the computer speakers, then test it using headphones. If the audio is only distorted while listening via the computer speakers, the circuitry or the speakers themselves may be faulty. Audio that doesn't work or makes static and/or soft "popping" noises can be a sign of a blown speaker/mic.
Failure to Open Disk Drive
The disk drive on your Sony Vaio PCG-71C11L will not open.
Broken/Defective Optical Drive
If your Sony Vaio PCG-71C11L optical drive does not open or does not read CD's or DVD's, the optical drive may be broken and needs replacing.
Battery Loses Charge
The battery on your Sony Vaio PCG-71C11L doesn't charge to full or loses charge faster than normal.
Broken/Defective Battery
If your Sony Vaio PCG-71C11L loses charge faster than normal, there may be a problem with the connection to the computer, or the battery itself might need replacing.
Broken/Cracked Casing
The casing on your Sony Vaio PCG-71C11L is popped open or cracked in places.
Broken/Faulty Casing
If the casing on your Sony Vaio PCG-71C11L has popped open, it may have just come loose or could need replacing. If the casing is cracked, it will need replacing.Sony Vaio VGN-FS640 Optical Drive Replacement
Full RAM but Empty Storage
The RAM on your Sony Vaio PCG-71C11L is faulty
Broken/Faulty RAM Sticks
If the RAM sticks on your Sony Vaio PCG-71C11L are broken or faulty they will need replacement Sony Vaio VPCW21FX RAM Replacement as soon as possible to keep the functionality of the computer at 100%.
0 Comments
