Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Handset Fails To Register With Base
The handset is not responding to and/or communicating with the base
Faulty Battery
The battery pack might not be properly attached to the body of the phone. Check to see if the connection of the battery pack is good. This can be done by removing the battery pack and reattach it. Charge for 12 hours for best performance quality. If the phone still does not turn on, the battery is faulty. Consider purchasing a replacement battery.
Handset Out Of Sync
The handset might be out of sync with the base and not communicating with the base properly. Place the handset back into the base and let them sync for 5 minutes.
Handset Out Of Proximity
The handset might be out of the radius and cannot sync with the base. Consider moving closer towards the base and get into the range in which the base can receive signal from the handset.
Distorted Audio Output Over The Handset Speaker
The audio coming out of the handset is not clear
Electronic or Other Interference
The handset and base might be placed too close in proximity to other electronic products, which is interrupting the signal between the handheld and the base. Consider changing the location in which the base is placed, the most suitable location will be a location where there are no other electronic products.
Handset Out of Proximity
Volume Is Too High
The distortion might be due to the volume of the handheld being turned too high. Adjust the volume by playing with the volume buttons.
Faulty Speaker
Follow the steps to check for Faulty Connections/Wiring and Volume.  If speaker is still dysfunctional, it is most likely broken. Consider purchasing a new one to replace it.
Distorted Answering Machine Audio
The audio on the answer machine is distorted
Volume Too High
The distortion might be due to the volume of the handheld being turned too high. Adjust the volume by playing with the volume buttons on the base.
Check to make sure that the base is properly plugged in. If it is, make sure the light on the base is on. If the light is not on, the wiring might be faulty. Look for exposed wires, if found, consider purchasing a replacement wire.
Faulty Speaker
Handset Fails To Retain Charge/Failure to Turn on
Battery life of the handset is bad and seems to not retain charge well
Faulty Battery
Difficulty of The Other Person Hearing You
The person on the other end of the line whom you are speaking to cannot hear you well
Not Speaking Directly Into The Handset
The failure to capture and register your voice well might be due to the way you are using the handset. Ensure that you are speaking directly into the handset to ensure the best performance of the microphone.
Faulty Microphone
Try speaking directly into the microphone, if the person on the other end still struggles with hearing you, then the microphone might be faulty. Consider replacing the microphone.
Dylan Wengerd
66 Reputation
0 Guides authored
IUPUI, Team 3-3, Harley Fall 2016 Member of IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Members
84 Guides authored
3 Comments
I was able to program the answer machine and the recording comes on but it does not tape the message left.
franch43 - Reply Share
I was able to program the answer machine and the recorded msg to leave a msg comes on but the recorded msg from the caller does not record.
The machine rings, but greeting does not come on.
tatreau210 - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 778
