Sony Ericsson is Unresponsive and Frozen
Phone is turned on but will not respond to anything.
Internal Issue
Remove the battery to force shut down the phone and put the battery back in and turn it on again.
Sony Ericsson Will Not Turn On
No matter how you try, the phone just will not turn on.
Broken Battery
There might be a problem with the battery. It either doesn't charge anymore, is out of battery, or the phone no longer recognizes it. Replacement might be necessary.
Broken Keypad
The phone is no longer receptive to the turn on button on the phone keypad. Replacement is necessary.
Sony Ericsson Is Not Charging
The charging indications do not appear when you plug in the adapter into the charging port..
Damaged or Broken Battery
The battery might not charge or the phone might not be able to recognize the battery.
Broken Charging Port
Charging port might not be able to charge the battery anymore. Replacement will be necessary.
Broken Charging Adapter
The adapter might have trouble receiving electricity from a wall port. There is either an issue with the adapter or there is no electricity coming from the wall port.
Sony Ericsson Does Not Display Anything
The phone is on, you're sure of it. Just nothing shows up.
Bad Display
If the phone still vibrates and makes sound but does not show anything when you turn on or turn off your phone, there is likely a problem with the phone display. It is possible that the screen might have trouble connecting to the rest of the hardware or is broken. Replacement of the screen or phone is likely unavoidable.
Broken Screen
There is a crack in the screen or physical issues with the display.
Bad Display
The screen needs to be replaced.
CY Tan
7 Reputation
0 Guides authored
Cal Poly, Team 6-36, Regan Fall 2012 Member of Cal Poly, Team 6-36, Regan Fall 2012
CPSU-REGAN-F12S6G36
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 205
