Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Problems with the memory
If the device isn’t saving/recording videos:
Faulty memory Card
·     If there is an error with the memory card, you will need to fist check if a memory card is slotted in the device and that the battery latch is secure, if not then slot one in. If the problem still persists, you will need to check if the memory space in your card is full. if full you will need to replace it or transfer the data to an external source.
Problems with the battery
  If the camcorder doesn’t turn on it:
Faulty battery
 If the camcorder doesn’t turn on it, check if the battery pack has been placed inside the camcorder, if not then install a battery into the device. If a battery pack is in place, check to make sure the device is charged or connect it to the A/C power adaptor supplied.
Power Automatically shuts off
When using the device, ensure that the auto-off feature has been properly set up. this feature automatically turns of the camera after a certain period
Shortened battery life
When using the camcorder, the temprature must not be used used below 32 degrees fahrenheit. If the operating temp is not the issue, then the battery pack has reached its lifespan and cannot be recharged. if the battery has reached it lifespan, replace
Problems with Recording
If the camcorder isn’t recording video.
Use the mode button to set the camcorder to movie record mode.If that does not work, the storage on the device may be fully used up and must either be replaced or formatted.
Problems with File Transferring
If the camcorder is have issues transferring files to a computer, it may be necessary to  install any software provided with the camcorder on you computer. (Video Codec) If this does not work make ensure the USB connector is inserted in the correct direction and the jack plugged into the camcorder tightly.
Cracked Lens
Check lens for damage or debris affecting picture quality. If the lens is cracked, promptly replace with new lens before attempting to operate.
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 46
All Time: 874
