Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Samsung NP530E5M Troubleshooting
Samsung Electronics Series 5 Notebook, model number NP530E5M
Device Not Turning On
The laptop shows no signs of powering up.
Faulty Battery
If the laptop can power on with the charging adapter plugged in but not without it, the battery might need to be replaced. Follow this guide to replace the battery if help is needed.
Broken Screen
Check to see if the fans and/or power light come on after powering the device. If they are but the screen stays black then the device is turning on but the screen is broken. Follow this guide to replace it.
Battery not able to hold charge
Devices cannot run for long or at all without being plugged in.
Faulty Power Adapter
Ensure the power adapter is properly plugged into the device and wall outlet. If the device is not saying it is being charged and if multiple outlets have been used, the adapter may be faulty and need replacing.
Faulty Battery
Overheating
The laptop powers down without warning.
Dust in Fans or Vents
Dust buildup can cause a laptop to overheat. Using a can of compressed air, carefully blow out any dust or dirt that has settled in and around the fan and vent. Overheating could also be caused by dirt or dust buildup in other areas of the laptop, such as the hard drive or RAM. Make sure these areas are free of any dust or dirt as well by using the compressed air.
Vents Obstructed
A lack of adequate airflow can cause a laptop to overheat. To make sure the air pathways are not being obstructed, try elevating or propping up the laptop so the vents are uncovered. If this doesn’t help, your fan may need replacing. A guide for this can be found here.
Dying Battery
Keeping the laptop plugged in constantly will cause the life of the battery to deplete at an accelerated rate, causing the battery to overheat. Remove the battery from the laptop while keeping it plugged in. If the problem abates, replace the battery.
Not Enough Storage
Device has used up all of its memory.
Hard Drive Full Error
If your computer shows an error message when you try to save a file, your hard drive may be full. The simple fix would be to delete unneeded files. Another option is to use an external hard drive or install an upgraded hard drive in order to create more room on the device.
Device Running Slow
Device takes a long time to load or frequently crashes.
Not Enough Ram
If your computer struggles to load basic programs or crashes frequently, you might need to either upgrade your RAM or replace it.
Hard Drive Error
This may be caused by incorrect shut down procedures. The first thing to try is restoring the original windows operating system. If that does not work, your hard drive probably needs to be replaced.
0 Comments
