Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet will not charge
When you plug in the tablet to a power source it will not charge.
Charger cord is broken
See if the cord to the charger is frayed or pinched, if so try another charger.
Try resetting the tablet
see "How to reset my tablet"
Bad battery
The battery in your device may have gone bad try replacing it.
SKYTEX SP1020 Battery Replacement.
Touchscreen will not respond
Screen will light up but will not respond when you touch it
Bad logic board
Try resetting the tablet. See "How to reset my tablet". If that doesn't work you may have to replace the logic board.
Logic board Replacement.
Screen is broken
If this is the case you will have to replace the screen of the tablet.
Sound will not work
You try to play music or a video and the sound will not work
The sound has been muted
Go into settings and make sure that your device is not muted
Speaker is blown
Still no noise coming from the speaker, if this is the case than you must replace the speaker
Speaker Replacement
Camera will not work
Camera will not work or images appear blurred
Camera is dirty
Try cleaning the camera with a micro fiber cloth and a little bit of glass cleaner
Problem with the logic board
Try resetting the tablet, see "How to reset my tablet"
Camera is broken
When using the camera the screen goes black, if this happens than the camera is most likely broken and needs to be replaced.
My Wi-Fi says it's 'Disconnected' after I attempt to connect
The Disconnected status means that the tablet is not connected to any network
Incorrect password
Make sure the correct password is entered when connecting to your wireless network. This password could be on the bottom of the router or a password that was created by someone when the Wi-Fi device was originally set up.
Too far from router to get a steady connection
Move your device closer to the router, and make sure the router is on. See if it will connect to other devices
To reset the tablet, unplug it from the power source. Press and hold the Power button for 10 seconds and then plug the power source back in. Press and hold the power button for an additional 2-3 seconds.
Anthony Vitali
293 Reputation
2 Guides authored
10 Comments
I tried to reset it but its still doing the same thing , it charges fine, just when I turn it on it doesn't fully load up it gets stuck at the skypad screen and  stays there, the screen doesn't go black, it doesn't fully load. can it be fixed or is it a total loss only had it for a year.
donna greene - Reply Share
I tried the steps above to reset and it still doesn’t work. What do I do now to reset my sky pad 10
Tracy Lindstrom - Reply Share
Sky pad 8 won't reset, touch screen won't let me press buttons on touch screen, I've tried several times, it will go to code entry screen, but can't enter password due to no response on touch screen screen
Jeremy J Wilkinson - Reply Share
Will not expect my pin
Lance Yount - Reply Share
Can't activate government tablet won't accept pin needs reactivated
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 35
All Time: 4,061
