Student In Progress
This wiki is being worked on by hardworking students.
Scroll wheel is skipping or not registering
Whether your playing a game or doing office work mouse problems plague us all this guide will go over the most common problems and solutions to the Razer Cobra Pro.
Cautions:
- First disconnect the mouse from any USB port it may be plugged into.
- Be cautious of sharp edges after cracking open the shell as the edges may be sharp.
- Be cautious of disconnecting cable to PCB circuit.
Common Problems:
Encoder Problems:
- Crack the Razor Cobra Pro shell open from where the bottom and top shell meet.
- Check to see encoder is smudged or dirty.
- Check to see if encoder is faulty or damaged in anyway.
Dirt or Blocked Scroll Wheel:
- Disconnect the mouse from the computer.
- Inspect the gaps around the scroll wheel for dust or debris.
- Rotate the scroll wheel in both directions to check for any obstructions.
- Use compressed air around the wheel to loosen up and remove and debris.
- Reconnect and the mouse and test scrolling.
Incorrect Scrolling Settings:
- Open settings -> Bluetooth & devices -> Mouse in Windows.
- Check the scrolling settings and adjust the number of lines per scroll.
- Test the wheel in multiple applications.
- Check whether the problem occurs when scrolling slowly, quickly, or in either direction.
If problems persist check to see if there is a software update:
- Go to settings.
- See if you're on the latest version (Synapse 4).
- If you're on an older version click update firmware.
0 Comments
