Philips 48pfs8159 only philips logo and restart reboot loop
Philips Android TV 48pfs8159 only shows the Philips logo and starts again.
You can fix the error by downloading the latest tv update from Philips and extracting the file onto a USB stick. Important: Extract the file into the root folder of the usb stick. Do not create an "upgrade" folder (this is how it is in the Philips instructions downloaded with the update, but this is wrong to fix the error. Only the update file on the stick must be without a folder. Connect the USB stick to the TV. Remove the power. Simultaneously press on the joystick at the bottom right of the TV and pull down and hold it in such a way that the power is plugged in again (it may be necessary for two people). Hold the joystick as long as the tv turns on is displayed and "No command" is displayed android is in recovery mode. Now select "delete cache" via the remote control and confirm with ok on the remote control. Then select "reset factory defaults". Select "install software update" as the last step from external storage ". The update file from the usb stick should now be displayed. Select, print ok and the entire operating system will be reinstalled longer) in the "reboot" menu. The TV reboots and will work normally again. Now all settings have to be made again but the TV is alive again.
Special thanks to these translators:
100%
Troy is helping us fix the world! Want to contribute?
Start translating ›
112 Comments
Danke für die Anleitung. Die hat mir schon mehrmals geholfen. Der Fernseher geht gefühlt jedes Jahr “kaputt”. Ich bin ja der Meinung, dass der Hersteller das schon fast absichtlich macht. Immer wieder neue Probleme, bis irgendwann garnichts mehr geht. Mithilfe dieser Anleitung habe ich es schon zwei mal den TV wieder hingekriegt, obwohl man sonst nur die Auskunft kriegt, das Mainboard sei bei dieser Art Probleme defekt.
Kurz nach Ablauf der Gewährleistung ging er einfach nicht mehr an. Bootloop. Diese Anleitung hat geholfen.
Kurze Zeit Später war angeblich das Mainboard ganz defekt, mein bekannter konnte mir das Gerät auf Kulanz reparieren lassen.
Nun jetzt 1,5 Jahre Später erneut neue Probleme. Zuerst ging kein Sound mehr (nur noch über Kopfhörerausgang), alles versucht - keine Besserung. Dann ging er wieder garnicht mehr an. Recherchen sagten hier wieder nur “Mainboard defekt”. Die Anleitung hat erneut geholfen und der TV läuft nun mittlerweile wieder seit einem Monat stabil, als wäre er neu.
Patrick N. - Reply
Ich kann dem ganzen nur zustimmen hat heute bei mir auch alles funktioniert! Eine Spitzen Anleitung!!! Vielen dank! Mein Fernseher ist nämlich auch 26 Monate alt und er hatte immer wenn er aus war neu gebootet und das dauerte mir immer zu lange, bis ich ein Bild hatte. Dachte mir mach ein Software Update und dann wird schon laufen. Sch…. war Bootloop!!! Dank der Anleitung läuft die Bude wieder!!! DANKE!
Martin Thiemert - Reply
Mega Hilfreich!
Habe einen ca 5 Jahre alten Philips 49PUS7909/12 und da funktioniert dieser Tipp auch.
Hatte plötzlich die Boot-Dauerschleife - nichts ging mehr - und nach Anwendung des Tipps funktioniert das Gerät wieder - mal sehen wie lange.
Habe das neue Image im Ordner “upgrade” abgelegt und das Betriebssystem wurde neu installiert.
Vielen Dank!
Gerhard Wendland
Gerhard Wendland - Reply
Hallo,
Habe Deinen tollen Trick mit dem Problem versucht genau wie Du es beschrieben hast. Der TV startet, das Philips Logo erscheint und dann schaltet sich der Fernseher wieder aus. Klappt leider nicht. Hast Du noch einen anderen Tip, oder ist mein Mainboard wirklich kaputt?
Vielen Dank
Christian
Christian le Bret - Reply
kommst du ins Android Recoverymenu durch das vom Strom nehmen, joystick am TV rücken nach unten halten und Stromzufuhr gleichzeit herstellen?
Patrick N. -
