Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera does not turn on
When the power button is pressed, the camera is unresponsive
Dead battery
Your battery may be dead and in need of charging. Take the battery out of the camera and put into the charger. After a few hours, put the battery back into the camera and try to turn it on again.
Incorrectly installed battery
The camera will not turn on if the battery is incorrectly oriented. Remove the battery and make sure that it is not backwards when you put it back in.
Broken motherboard
If the battery is charged and correctly inserted the problem may be that the motherboard is broken, so you will need to replace it using this guide.
Camera does not have any audio
Recorded videos have no sound when played back or there are no beep sounds
Volume is disabled
Press the MENU/SET button then select the Setup menu icon. Using this menu, you can adjust the volume from 0 to 6 under Speaker Volume. Using the same setup menu, you can also change the volume of the beeps from mute/low/high.
Image has irregularities in it
Pictures have spots or blurry sections in them
Outer lens contains dust or contaminants
The exterior lens often times accumulates dust and other debris that distort the image. With a soft micro cloth and some clean water, gently wipe away any particles that might be on the lens. If cleaning the lens does not remove the spots in the image or improve the resolution, the inner image sensor might be the one contaminated.
Viewfinder is broken
If the image is inconsistent when compared to the LCD screen, or if it's just black through the viewfinder, it's likely that it is broken. To replace the viewfinder, follow this guide here.
Camera doesn't connect to computer
The camera is unable to upload pictures on to the computer
Dead battery
If the battery is dead, the camera wouldn't be able to respond to the connections. Be sure that the battery is fully charged.
Wrong port on the computer
Be sure that the camera is completely connected to the correct port on the computer.
LCD monitor is not turning on
The LCD screen is unresponsive or not displaying any images
Dead battery
Be sure that your battery is fully charged otherwise the camera will be unresponsive.
Viewfinder display setting is on
If you are trying to take a picture through the LCD screen but the image is not showing, your camera maybe set for viewfinder display. Press LVF button and switch to LCD monitor display.
Broken LCD screen
If all other functions of the camera are working, your LCD screen is broken. Follow the repair guide to replace your LCD screen.
Lens fail to extend
Lens won't extend
Malfunctioned device software
Resetting the camera to its original factory settings can be enough to resolve any bugs you might come across. To reset to factory settings, press MENU/SET. Then press </> to select the "Setup" menu, followed by the MENU/SET button. Select reset and then press MENU/SET. A menu will appear, select "yes" and then press MENU/SET.
Camera won’t zoom or focus
When the you try to zoom with the camera, it only shows a message called system error
System Error Zoom, System Error Focus, System Error Lens
If one of these messages appear on your camera, sometimes it might just be an error with the camera instead of one of its parts. Remove the battery for 60 seconds and then reinstall it into the system.
Back panel or the back buttons are damaged
The back panel and its buttons can be damaged, or worn down from excessive use
Broken panel/buttons
If either of these parts are cracked, then replacement becomes necessary. To reach and replace the back panel, follow the repair guide here.
Alberto Rodriguez
1 Reputation
0 Guides authored
Cal Poly, Team 21-3, Maness Winter 2017 Member of Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Members
72 Guides authored
4 Comments
Powers on but the camera fails to zoom on image. Changing settings does not take effect except powered off and then on again.
Taiye Adeyanju - Reply Share
Only on and off and snap buttons working.
Impossible to scroll to
Hi. Thanks for the info. I replaced my LCD but still get no display on it when toggling from LVF. Everything is good in the LVF. Tried doing a reset, still nothing. Any ideas? I’m assuming one of the ZIF’s isn’t fully seated.
Mike Rowave - Reply Share
Could be a bad replacement LCD, but now I’m not sure the original was no good. The camera came to me with the LCD already not working, so I don’t have any history on it.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 2,738
