Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Nokia 3 V Does not Charge
When trying to charge the Nokia 3 V, the charger does not charge past a certain point. Try this guides to get the phone to charge all the way.
Corrosion or Debris
Overtime debris can be in the charging port and make it difficult for the phone to fully charge. There are multiple solutions to this. You can use compressed air and blow it out. Finding a toothpick is a great solution or a soft microfiber cloth.
Improper charging
Sometimes using the wrong charger or leaving a charger in for an extended amount of time can cause this. Using the charger made by the manufacturer is important to prevent improper charging. Charging overnight can cause heating and make the battery faulty.
Wear and tear
Overtime the battery can degrade and make the charging harder to do. Using it for long periods of time without taking a break and cause a heated battery and make it difficult to use.
Temperature
Having the battery in extremely hot or cold temperatures can create a faulty battery. Keeping it in room temperature settings can help this.
Software issues
Having apps in the background drains the battery and causes issues with the phone when they are in the background for an extended period of time. Power the phone off and give it some time to rest then try again.
JC Petrongolo
159 Reputation
0 Guides authored
UMass Dartmouth, Team 3-2, Santin Fall 2024 Member of UMass Dartmouth, Team 3-2, Santin Fall 2024
UMASSD-SANTIN-F24S3G2
4 Members
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 71
