Student In Progress
This wiki is being worked on by hardworking students.
Bluetooth Pairing Issue
The speaker uses Bluetooth to display the battery level to your device. If the pairing is interrupted or disconnected, the battery level may show an incorrect percentage even if the battery is fine.
  • Turn the speaker on
  • Press and hold the volume up and volume down buttons at the same time for about 3 seconds until you hear four beeps
  • Disconnect the Bluetooth and use the "Forget Device" option with the device that it was paired to
  • Turn Bluetooth on and off on the device that the speaker was paired to, after turning it back on connect to the speaker once again
Uncalibrated Battery
If you know you have charged the battery fully, but its showing a battery level that is inconsistent with what you believe should be accurate, try draining the battery and allowing it to fully charge over a long period of time. This will ensure that the battery is fully charged, even if the information coming from the speaker is incorrect.
  • Allow the speaker's battery to be fully drained
  • Turn off the speaker and connect it to the charging cable
  • Charge the speaker for 6-8 hours to ensure a full charge
  • Turn the speaker back on and connect it to your device
Faulty Charging Cable or Port
A damaged cable or a port with dust or dirt in it can cause the speaker to charge incorrectly and the reported battery level will seem off.
  • Use the cable to charge the speaker.
  • If the charging indicator doesn't turn on, the port or cable may be damaged.
  • Clean the port, and inspect the cable.
  • If the charging cable is damaged, replace the cable and retry
  • If the new cable doesn't work, see the charging port replacement guide to replace the charging port.
Worn Out Battery
Batteries can lose capacity with age, and a worn out battery can lose charge quicker than expected. If everything else fixed the issue, an old battery is likely the cause of the incorrect battery level.
  • Review these instructions to see how to access the battery <instructions page not made yet>
  • Remove and replace the battery
Author
with
ThHuyT
202 Reputation
0 Guides authored
UMass Dartmouth, Team 1-2, DeLuca Fall 2026 Member of UMass Dartmouth, Team 1-2, DeLuca Fall 2026
UMASSD-DELUCA-F26S1G2
3 Members
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 42
All Time: 42
