Content
Tablet Will Not Power On
  • Faulty Power Adapter
  • Faulty Battery
  • Tablet Will Not Charge
Malfunctioning Power Button
  • Power Button is Missing
  • Power Button is Stuck
Video Distortion
  • External Display
Audio Distortion
  • Loose Headphone Jack
  • Non-functional Speaker
  • Unable To Use Microphone
Broken Casing
  • Crack in Front Screen
The tablet will not respond or show any sign of operating.
Check to make sure the power adapter is plugged in. If it is, make sure the light on the adapter is on. If the light is not on, the adapter is faulty. Consider replacing the power adapter.
Faulty Battery
If the adapter is plugged in, make sure the adapter is connected to the tablet. If the tablet only powers up when the adapter is plugged in, regardless of charging time, then the battery is faulty. Consider replacing the device's battery.
If the adapter is plugged in, and the battery is not charging consider purchasing a new charging adapter.
The power button will not respond or is not on the device.
If the power button is missing from the tablet, it may need to be replaced.
Power Button is Lodged
When the button is lodged and the device will not respond, try to use more force to press the button down. If it continues to not respond, consider replacing the power button.
Video Distortion
The display of the screen is malfunctioning.
External Display
The tablet screen may be operating incorrectly in terms of resolution, formatting, color, etc. First, check the device’s display settings, and reset to default settings. If the screen is still malfunctioning, then the screen may need to be replaced.
Audio Distortion
The audio (sound) input/output is not functioning properly.
Make sure headphones are working properly before attempting to listen to audio through the tablet.
If the audio is cutting in and out, then the jack is most likely loose. Make sure the headphones are fully inserted into the tablet. If the audio is still distorted while listening, the audio jack may be faulty.
If the audio output from the tablet is not responding, try turning up the volume level. If the speaker still does not respond once the volume is turned up, the speaker may need to be replaced.
If the microphone is not responding to vocal input, check to make sure the microphone is turned on. If the microphone is turned on and is still not responding, it may be faulty and needs to be replaced.
Broken Casing
The casing on the exterior of the tablet is broken or cracked.
If you have a crack in the screen on your tablet, you will have to have it replaced. Purchase a new case and replace the old case.
Cole Smith
12 Reputation
0 Guides authored
1 Comment
Reset the code to open screen
Lucy De La Garza - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,434
