Student In Progress
This wiki is being worked on by hardworking students.
Logitech G433 Won't Connect
Logitech G433 does not connect to the device, so audio is not coming out of the earcups. This page offers some common solutions that we hope will help you out!
Logitech Headphone Jack Not Plugged in All the Way
If the headphone jack is not fully inserted into the device's port, then sound may play out of the device instead of the ear cups/speakers. Check that you feel or hear a slight click when plugging in the headphone jack.
Logitech Headphone Jack or Port Needs to be Cleaned
If the headphone jack or port contains dust and debris, this can inhibit connection of the Logitech to your respective device. Check the headphone jack and inside of the port and clean out dust/debris carefully if needed. Using a cotton swap or light tapping to clear the port is a good place to start.
Using a PC Connection Can be More Complicated:
If you are wanting to connect the Logitech to a PC, it can get confusing when needing to use different cables to connect to your device. Below covers the connecting process for two common cables used.
USB DAC
- Plug the USB DAC cable into your computer’s USB port.
- Plug the Logitech headphone jack into the other side of the USB DAC.
- Go to the PC settings and select the USB DAC as your audio output.
Splitter
- Use the 3.5mm microphone and headphone plugs and connect each to their spots on the PC (jacks are usually matched with a pink or green spot on the PC).
- Plug the Logitech headphone jack into the opposite side of the PC splitter.
- You may need to go to the PC settings and select the splitter as your audio output.
If further support related to specific device connections visit Logitech's connection support for the G433:
Connect the G433 gaming headset to compatible devices – Logitech Support + Download
Your Respective Device is Already Paired to a Different Bluetooth Device
If your device is already paired to a different audio device via Bluetooth or wired connection, the Logitech may not connect when inserted. Check that no other audio devices are connected to your device via Bluetooth, then proceed with plugging in the headphone jack. The Logitech will now be the primary device for audio to transmit to.
Water Damage
If the port of your device or the speaker of the Logitech came into contact with water, this would prevent the Logitech from connecting and may signal for replacement of the water subjected part. Before jumping to this, let the Logitech or the device port dry for a few hours before trying connection again.
0 Comments
