Lefant M210 is Not Cleaning Effectively
If your Lefant M210 robotic vacuum cleaner isn’t cleaning effectively, it can be frustrating. if this is happening to you, here’s a detailed guide to help you troubleshoot and improve its cleaning performance.
1. Check Cleaning Mode
  • Cleaning Mode Selection: Ensure that the vacuum is set to the appropriate cleaning mode for the area you want to clean. The Lefant M210 typically has several modes, including:
    • Auto Mode: For general cleaning of most areas.
    • Spot Cleaning Mode: For targeted cleaning of specific spots with more intensity.
    • Edge Cleaning Mode: For cleaning along walls and edges.
  • Switching Modes: Use the remote or the app to switch modes as needed.
2. Surface Type
  • Hard Floors vs. Carpets: The vacuum may perform differently depending on the surface. If you’re cleaning carpets, ensure that the vacuum is on a mode suitable for carpet cleaning, which might require more suction or a different brush pattern.
  • Testing on Various Surfaces: If you notice poor performance, try moving the vacuum to a different type of surface and observe its cleaning efficacy.
3. Clean Filters and Dustbin
  • Check Dustbin: If the dustbin is full, the vacuum will struggle to pick up dirt. Empty it regularly, ideally after each use.
  • Inspect Filters: Clogged filters can significantly reduce suction power. Remove the filters and clean them according to the user manual’s instructions. If they are damaged or excessively dirty, consider replacing them.
  • Cleaning Frequency: Make a habit of checking and cleaning the filters and dustbin to maintain optimal performance.
4. Battery Life and Performance
  • Low Battery: If the vacuum is running low on battery, it may not clean effectively. Ensure it is charged before use.
  • Cleaning Time: If the vacuum is running for a shorter time than expected, consider checking the battery health or replacing it if necessary.
Adam Magana
51 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 144
