Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Difficulties Charging and Maintaining a Charge
Battery drains and dies quickly.
Too Much Multitasking
Having too many apps open at once may put stress on the battery, and closing out apps that you aren’t using or don’t plan to use in the immediate future may fix that. Also make sure that other services like Bluetooth, cellular services, and wifi are turned off when not in use for maximum battery life.
Dirty or Dusty Port
The port will gather debris through day to day use. Try blowing on the port with a can of air or using a microfiber swab to force the debris out of the port.
Faulty or Damaged Charger
The charger itself may become damaged. The easiest and only option is to replace the cable. An easy way to test this is by plugging the phone into a different charger that you know is working. If the phone begins to charge properly with the new charger, the old charger may be the issue.
Physical Port Damage
If your phone is not easily disconnected from the charger or if the charger does not plug all the way in, the port may have sustained some damage. To diagnose, compare the port of the device to images of a micro-USB. Confirm that the charging port has a thin metal connector at the bottom of the charging port and that the charging cable still fits in the port. If your port does not match the shape of the charger, then it will be necessary to replace the port.
Faulty Battery
Poor battery performance that cannot be attributed to high usage may be the result of an old or faulty battery. If the battery is compromised here there may be no way to revive the battery. In this case, it will be necessary to replace the battery with a new one. An easy way to test this is to plug the phone into a new charger that you know is working. If the phone continues to not charge or charge improperly, then the problem is most likely the battery.
Replace the battery using this guide.
Unresponsive Touch Screen
The screen does not respond to touch accurately or at all
Physical Damage
Damages to the screen are usually observable. Look for cracks in the display, leaks in the LCD (black or purple splotches in the screen), or stripes of any color.
Replace the screen using this guide.
App Crashes
If your phone freezes in the middle of using an app, then the problem may be the app itself. First, try closing the app that it froze on, and if the screen is completely unresponsive it may be necessary to restart the phone
  • Press and hold the Power button (located on the back) until the Phone options screen appears then release.
    • If the device is unresponsive, press and hold the Power button until the device powers off (approximately 10 seconds) then release.
    • From the Phone options screen, tap Power off and restart.
  • From the Power off and restart prompt, tap RESTART to confirm.
** Allow several minutes for the process to complete.
  • If unable to perform a soft reset (hold down power button for 30 seconds), remove then re-insert the battery.
Camera Not Capturing Images
The camera is unable to take pictures.
Obscured Lens
If the phone is showing a black or otherwise distorted screen then the lens may be dirty. Make sure that the lens is clear and there are no objects blocking the camera lens, or that the lens does not have any noticeable smudges or marks.
Frozen App
The camera app may “freeze”, this can usually be resolved by closing and restarting the app. Extreme cases may require that the phone be restarted.
Damaged Camera
Either camera may become unusable due to damages. In this case, it will be necessary to replace the damaged camera.
Replace the front facing camera using this guide.
Replace the rear facing camera using this guide.
Audio Jack is Not Producing Sound
No sound is played when something is plugged into the audio jack
Broken Cables
The cable that you are plugging in can become damaged and not continue to transmit the signal. To test this, try plugging a different cable that you know works into the audio jack. If the new cable works, then your original cable may be broken.
Dirty Jack
Dust and debris may accumulate in the jack. Try blowing into the jack with a can of air or using a microfiber swab to clean out the jack.
Damaged Jack
The audio jack may become damaged or bent out of shape. If you notice any damage to the phone jack it may be necessary to replace that component.
Phone Won’t Turn on
The phone partially or fully doesn’t turn on
Make Sure it’s Charged
If the battery isn’t charged to a high enough level the phone will not turn on. Try charging the phone for a longer period of time, or try using another charger that you know works properly.
Software Out of Date
Phone software is updated fairly frequently, and not updating can eventually result in problems using the phone. Try force restarting the phone by holding down the power key for 30 seconds. Release the power key if the phone turns on. Once it turns on, verify that the phone has all of its software up to date.
Check For Damages
Examine the phone for irregularities or noticeable damages to locations such as the battery, charging port, or power button. If you notice damages, follow the appropriate guide to repair those components.
Still Won’t Turn on
If your phone still won’t turn on it might require a restart. Try a forced reset first by holding down the power key for 30 seconds. If the phone still does not turn on it may be necessary to perform a factory reset. WARNING: this will erase all data on the phone, so make sure you have a recent backup.
Factory Reset Procedure
Author
with
Tiffany Wheeler
308 Reputation
2 Guides authored
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Members
84 Guides authored
1 Comment
Still doesn't power up what else could the problem be. I even tried other batteries or even a different charging cords and plugs
Chamorro Pride - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 4,253
