Kodak Advantix F350
Camera will not operate
Battery is weak or fully depleted
Verify the camera is on by looking at the readout on the top of the camera. If camera battery is fully depleted, the battery needs to be replaced. Refer to the repair guides for help replacing the battery.
Film has reached end of roll
Check the picture count on the top of the camera. If the picture count has maxed out, the film needs to be replaced. Refer to the repair guides for help replacing the film or rewinding the film.
Shutter not opened
The problem may be the shutter. Before taking a picture, verify that the shutter is manually opened on the front of the camera. Refer to the repair guides for help opening the shutter.
LCD panel is blank
Camera in sleep mode
Verify the camera isn't in sleep mode by pressing the shutter button on the top of the camera.
Shutter not opened
Pictures are dark
Front cover not open
On the front of the camera there is a lens cover that slides open. This cover needs to be open when taking pictures.
Lens should be cleaned
Your camera lens may be dirty. Wipe it clean with any soft cloth, but make sure it is clean. If lens is cleaned, but problem persists, lens may need to be changed.
Flash not working
If the flash is not working, there could be three issues. First, check to make sure there is a battery in the camera. Refer to the repair guides for a guide on how to change the batteries. The second problem may be the flash bulb. The bulb may need to be replaced. Refer to the repair guides for a guide on replacing the bulb. The Third could be the capacitor, this may also be broken, refer to the repair guide for fixing this.
Pictures are blurry
Camera was not held still
In order to ensure clear pictures you must hold the camera still while taking a picture.
Film is damaged
there could be defective film that could cause blurry pictures. This should be the last case scenario due to it being a rare occasion that film is bad.
Lens is dirty
Open the shutter and wipe the lens with a clean lint free cloth.
Crack in viewfinder
Viewfinder needs to be replaced
If there is a crack or line in the viewfinder, you will need to replace the viewfinder. The viewfinder is not necessary for normal camera use and will not affect the quality of the pictures.
David Cottrell
103 Reputation
5 Guides authored
UW Stout, Team 1-2, Zhou Fall 2011 Member of UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 525
