Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Car Will Not Turn On
When you switch on the Kid Galaxy Morphibians Explorer nothing happens.
Check the Batteries
It may be a quick fix. Check/Replace the three AA battery(s) as needed on the bottom of the Morphibian Explorer.
Broken On Switch
Check the internal and external On/Off Switch for damaged or loose wires. Replace if necessary.
Loose Power Wire
Check the ground and power wires, they may be loose or disconnected. Might be necessary to solder or replace the wires.
Receiver
The receiver may be broken or the power wires maybe be disconnected or stripped. Make sure to replace the receiver or solder the power wires back on.
Remote Will Not Turn On
When you use the remote nothing happens.
Check the Batteries
When you flip the remote check the two AAA batteries on the left handle under the battery cover. Replace the batteries if necessary.
Loose Power Wire
Make sure the power and ground wires are connected properly. If they are not connected solder the wires back on.
Damaged Chip
Check to see if the bus connections on the chip are not damaged. If they are replace the internal chip.
Bad Directional Pads (D-Pads)
The D-Pads are stuck or not moving fluently.
Internal Blockage
There may be something inside the controller that is preventing it from moving freely. Open the controller to check for a blockage.
Broken D-Pads
Open remote to remove and replace the directional pads.
Wheels Not Moving
When the car is on and working, but the wheels will not move.
Rubbing Wheels
The issue maybe the wheels on the RC car rubbing against the body. Loosen the wheels slightly to create some distance between the wheels and the body of the car.
Stripped Gears
Check the internal driving gears, the gears could be stripped. Is the gears are stripped replace the driving gears within the RC car.
Broke Motor
Issue may be the motor itself, replace the internal motor.
Jesse L
4 Reputation
0 Guides authored
USF Tampa, Team 1-2, Hickman Fall 2014 Member of USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Members
84 Guides authored
9 Comments
Verry detail. Thanks !
http://topremotecontrolcarstoys.com/
tolytien - Reply Share
Just got this one second hand. It says “solar powered “ on the side but is it? Mine has “Hybrid” on the spoiler at eh back of the car.
Sue
Sue - Reply Share
Just got one for my son and we went to turn on the remote control and the on and off switch is broke
Andrea parker - Reply Share
Just got it and there's no steering car moves
Tito Moreira - Reply Share
I just purchased one last year for my newborn son and I just opened it since he’s 10 months and it’s not working. New batteries and nothing broken. What’s wrong ?
Meyleeng Rodriguez Caro - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 6,100
