Inter-tel IP 8660 won't turn on
No matter what you do, you can't get your Inter-tel IP 8660 to turn on.
Bad Power Supply
It could be the case that the outlet your phone is plugged into is faulty. To check this, unplug the phone and try plugging in another electronic device you know to be working.
Bad display
It is possible that it appears nothing is happening because the display is bad. If a dial tone comes from the phone but nothing appears on the screen it is possible the display is bad and must be replaced.
Bad motherboard
If nothing at all happens with the phone the problem most likely lies in the motherboard.
My LCD screen won't turn on
The phone has power but the LCD screen is blank.
Contrast is turned up or down too much
This can be adjusted by first placing the phone in the cradle and dialing 303. Then adjust contrast using the volume up and down keys. When finished adjusting, press accept on the LCD screen.
Broken LCD screen
If not the result of a contrast issue, your LCD screen may be broken and need to be replaced.
No Audio
No audio can be heard from either the entire phone or specific parts like headset or speaker.
Firewall conflict
If the headset mode has been activated, the audio problems maybe the result of a firewall conflict. Contact your system administrator to see if the audio issue is the result of a firewall conflict. If so, they can resolve it.
Headset mode is off
If the audio problem is localized to the headset it may be because the headset mode is off. Headset mode can be turned on by placing the phone in the cradle and dialing 315 (Headset on feature code) or 317 (headset on/off feature code). If Headset was off either should work and the display should show HEADSET MODE ON.
Bad headset receiver
If the audio through just the headset is faulty and its not due to a firewall conflict or the mode is off the headset receiver may need to be replaced.
Bad Handset microphone
If audio output in headset is faulty and not due to a firewall conflict or the mode is off, the headset microphone may need to be replaced.
Bad Internal Speaker
If the audio problem is not the result of firmware conflict and is localized to just speaker mode this may indicate a faulty internal speaker that would need to get replaced.
Bad motherboard
If audio problem is not the result of firmware conflict but persists in all parts of the phone you may have a faulty motherboard.
Unresponsive/ Sticky buttons
Bad button pad
This will generally require that you tear-down the phone and either clean the connections between the buttons and the motherboard or replace the button pad altogether.
Author
with
Megan Buck
15 Reputation
1 Guide authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
84 Guides authored
1 Comment
We have three phone lines, only one seems to be working.  The phone company has checked it out and their lines area good.  If you push the button for those lines the phone says it is unplugged.  Where would it be unplugged?  Any one in the Philadelphia area that can look at it and repair it?
Total Turf Landscape Services - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 43
All Time: 3,432
