Food Processor Will Not Power On
The appliance will not run
Faulty Power Adapter
One possible explanation for your food processor’s failure to power on is an issue with the power adapter. The first thing to check is that the device is plugged into an outlet at all. Once you’ve made sure of that, make sure that the outlet the appliance is plugged into is working properly by testing it with other devices that you know work.
Overheating
Another possible explanation for this issue is overheating. Many electronics are affected by this issue, and it’s a fairly straightforward fix. If the issue is overheating, an easy way to solve it is by turning the unit OFF (O) and letting it stand for three to four minutes, then turning it back ON. If the appliance was overheated, it should work after this process.
On Switch is Not Responding
When you try to use the on switch, nothing happens.
Faulty Wiring
One possible explanation for the lack of response with the “on” switch is faulty wiring. It’s possible that the wire or wires attaching the switch to the motor are faulty or unattached. You can find out how to check inside the hub of the food processor HERE
Appliance Runs at Some Speeds but Not Others
The processor runs, but not at all speeds.
Faulty Wiring
This issue can also be due to faulty wiring. Find out how to check inside the hub of the food processor HERE
Motor Runs Without Blade
The motor runs, but the blade does not move.
Faulty Drive Shaft
One explanation for this issue is a faulty drive shaft. If the drive shaft turns easily by hand, it is possible that it is too worn. In this case, the drive shaft would need to be replaced. Click HERE to do so. If this is not the issue, it could be that the blade was not properly placed on the drive shaft.
Issues with the Blade and Bowl
Your problem could be as simple as the device needing cleaning or being improperly put together. It is essential that the blade is clean; if it is not, food and other particles stuck on the blade could prevent it from moving. In addition to cleaning, it’s important that the device be assembled correctly. The blade should be twisted securely into the bowl before the bowl scraper mechanism is inserted. If this order is reversed, the blade will not move.
Bowl is Leaking
Food is leaking out of the processing bowl.
The Bowl is Cracked
One fairly straightforward explanation for this issue is a crack in the bowl. Make sure you check for cracks around the base or sides of the bowl. If cracks are found, the bowl will need to be replaced.
Bowl is Improperly or Insecurely Locked In
If the bowl has not been locked in properly, leakage can occur. Check to make sure the bowl is twisted all the way to the right and is in its locked position.
Unit is not Shredding or Slicing Correctly
There are issues with the way the unit is performing.
Too Much Food in the Processing Chute
The main reason for this issue is simply putting too much food into the processing chute. When there’s too much food in the chute, it will be irregularly shredded or sliced.
Difficult to Remove Bowl from Base
The user is experiencing difficulties when trying to remove the bowl from the base.
The Snaps Need to be Lubricated
If you are having trouble removing the bowl from the base, try rubbing a small amount of vegetable oil on to the snaps located on the base. Also, do not store the food processor in the locked position.
Unit is Running Slowly and Catching at Times
The processor runs slowly and stalls.
The Processor Needs Cleaning
This is likely happening because the unit is dirty from use and needs to be cleaned. It is recommended that the parts are hand washed individually, as dish washers can damage the fragile parts.
Mack Bernard
639 Reputation
5 Guides authored
27 Comments
I ordered this food processor because it had good reviews & was reasonably priced. I used it 1 time to dice onions & I cannot get the lid to release from the bowl. I am seriously going to have to send it back with onions still in it. Please help!
Gina - Reply Share
Same problem. I didn’t even get it to work once and now I can’t get the food out. Does the light go on at the front when it is plugged in? My light did not go on.
emjay.turner - Reply Share
Yes this problem has caused more dinner preparations issues and frustration than I can think of. I actually threw it in the trash. Plus there is absolutely no customer service
Ruben Suarez - Reply Share
Same problem here! 1st time using it and I can't get the lid off to wash it!
M Garlington - Reply Share
There are small lidded areas on the bowl that trap dirty juice and I am unable to take apart for cleaning and cannot find instructions
C doucette - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 55
All Time: 20,877
