Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Will Not Charge
Laptop will not charge when plugged in to adapter.
Faulty Battery
If the device will only power up when it is connected via charging cable. Therefore, the issue is a faulty battery. You will need to replace the battery.
Broken Charger Port
Ensure the charging cable is completely plugged in. If the device is still not charging, try a different cable. If neither charger is faulty, then the issue pertains to the laptop itself. If the laptop only charges when you re-adjust the connection on the portal or you apply pressure, then the problem is a faulty charger port. You will need to replace the charger port on the laptop.
Unable to use Optical Disc Drive
The disc drive will not open or read the inserted disc.
Stuck Disc
Press the ejection button on the disc drive. After that, check to see if the indicator light activates. If it turns on, the drive is working properly. Moreover, there is something inside preventing it from opening. If there is a disc stuck inside, follow this guide to get the disc out.
Broken/Defective Optical Drive
Make sure there is nothing preventing the disc drive from opening. Press the eject button and see if the light indicator turns on. If the indicator does not turn on, the optical drive is faulty and needs to be replaced.
Unable to turn off Num-Lock
The Num-Lock keys are always on.
Run Registry is Always on
Check to see if the light indicator is on. If it is not activated, then the keyboard is faulty. If the Num-Lock indicator is on then the run registry is permanently on. Follow this guide on how to deactivate it.
Problems with Mousepad
Check to see that the mousepad is not off. Amber means that the touchpad is off. If amber is off then the touchpad is on. This feature is located on the top left corner of the touchpad.
CPU fan not Running
Check to see if vent is clogged and that nothing is blocked it. You might feel that the computer is getting warmer than it usually does. Follow this guide on how to replace the CPU fan.
Raul Rodriguez
51 Reputation
0 Guides authored
2 Comments
when i start my laptop it just gives me blank screen. please advise my email address is abdulnoor37@outlook.com
Mamun Miah - Reply Share
How long must i wait for a response? my notebook is a Hewlett Packard mt41. whenever i start my machine it just gives me a blank screen.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 27
All Time: 579
