Student In Progress
This wiki is being worked on by hardworking students.
First Steps
Before undertaking any time-consuming solution, consider the quick fixes below.
- Reset your computer or gaming software.
- Turn the controller on and off. This is done by preforming a long press (>5 seconds) on the mode switch button, then after waiting 30 seconds, performing a short press on the same button.
- Try resetting the controller. This is done by holding the settings button in the middle, and simultaneously pressing the minus button. Hold this for a couple seconds. A long vibration indicates that the reset process is complete, and the controller has been restored to its factory settings.
Outdated or Corrupted Firmware
The Gulikit KK3 Max sometimes may have issues with its software causing problems with inputting buttons. This can come in the form as random buttons being activated without user input, among other things. Bugs in the firmware may be the cause for this problem. Try the following:
- Try updating the firmware. The firmware download can be found on the official Gulikit website at the following link: https://gulikit.com/Download
- Try resetting the controller. This can reset any settings done to the controller. This is done by holding the settings button in the middle, and simultaneously pressing the minus button. Hold this for a couple seconds. A long vibration indicates that the reset process is complete, and the controller has been restored to its factory settings.
Broken Controller Port
When inserting the paddles into the controller, it is possible that the port itself may break. If this has happened, check the port for any physical irregularities. If the port looks misaligned compared to the rest of the ports, it may be physically broken.
- To replace the paddle port itself, see [insert repair guide link] for further instruction.
0 Comments
