Student In Progress
This wiki is being worked on by hardworking students.
Released on August 14, 2025, it can be identified by its ES model number. It features a high-precision joystick and trigger technology with a 256-level Hall Effect trigger for smooth analog input, durable Hall Effect joysticks with 2200-level precision, and low overall latency.
Low batteries
The batteries in your GuliKit ES could be low in power. If this is the case, the wireless signal will be weak, causing it to be unable to turn on. To fix this, first attempt to charge the batteries, and if the problem persists, replace the batteries instead.
Parts: GuliKit ES Controller compatible battery, USB-C to USB-C Cable 1 Meter
Tools Required: None
Defective Charging Cable
The charging cable that is provided with the GuliKit ES Controller may be defective and will not charge the controller properly. If this is the issue, then we recommend considering purchasing a new charging cable.
Parts: USB-C to USB-C Cable 1 Meter
Livia Lujan
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 16
Past 7 Days: 22
Past 30 Days: 22
All Time: 22
