Google Chromecast (4th Generation) Remote Will Not Pair
The voice remote fails to connect or respond to inputs on the Chromecast with Google TV interface.
This troubleshooting page will help you diagnose problems with the Google Chromecast (4th Generation) with Google TV.
Voice Remote Will Not Pair
The voice remote fails to connect or respond to inputs on the Google TV interface.
Dead or Weak Batteries
Even if the remote's status LED blinks, low battery voltage can prevent a stable Bluetooth connection.
  1. Slide off the back cover of the voice remote and remove the old batteries.
  1. Insert two fresh 1.5V AAA alkaline batteries.
  1. Verify that the status LED flashes twice when the batteries are inserted.
Remote Not in Pairing Mode
The remote may have lost its Bluetooth link to the Chromecast dongle.
  1. Press the physical button on the back of the Chromecast dongle until the TV screen displays Start pairing (or navigate to Settings > Remotes & Accessories > Pair remote or accessory using the Google TV mobile app).
  1. On the remote, press and hold the Back and Home buttons simultaneously for about 5 seconds until the status LED pulses white.
  1. Release the buttons once the remote appears and pairs on the TV screen.
Corrupted Bluetooth Profile
If the remote refuses to enter pairing mode or fails to connect, factory resetting the remote clears corrupted pairing data.
  1. Remove both AAA batteries from the remote and wait 5 minutes.
  1. Press and hold the Home button while reinserting the batteries.
  1. Keep holding Home until the status LED turns solid white, then immediately release the button as soon as the LED starts pulsing.
  1. Re-pair the remote using the pairing mode steps above.
No Video or Black Screen
The Chromecast powers on, but no image appears on the television screen.
Wrong TV Input Selected
The television may be tuned to a different HDMI port.
  1. Check which HDMI port the Chromecast is plugged into on the back or side of your TV.
  1. Use your TV's original remote to press Input or Source and select the matching HDMI port.
Loose HDMI Connection
The dongle's short HDMI cable may not be seated completely inside the TV port.
  1. Unplug the Chromecast from the HDMI port and inspect both connectors for dust or bent pins.
  1. Firmly push the Chromecast back into the HDMI port until it sits flush.
  1. If space behind the TV is tight, connect a short HDMI extender cable between the Chromecast and the TV.
Device Will Not Power On
The status LED on the Chromecast remains off and the device does not boot.
Insufficient USB Power
Most television USB ports do not supply enough amperage to run the 4th Generation Chromecast.
  1. Unplug the USB-C power cable from the TV's USB port.
  1. Plug the USB-C cable directly into the original 7.5W (5V, 1.5A) Google wall power adapter and connect it to a working wall outlet.
Faulty Power Cable or Outlet
A damaged USB-C cable or switched wall outlet can cut power to the dongle.
  1. Test the wall outlet by plugging in another small device or lamp to confirm it has power.
  1. Try a different known-good USB-C cable and 5V/1.5A+ power brick to rule out cable failure.
Wi-Fi Will Not Connect
The Chromecast cannot find or stay connected to your wireless network.
Router Out of Range or Interference
Being mounted behind a wall-mounted TV can block 5 GHz Wi-Fi signals.
  1. Restart your Wi-Fi router and unplug the Chromecast from power for 30 seconds, then plug it back in.
  1. Try connecting to the 2.4 GHz band of your router instead of 5 GHz for better range through walls and TVs.
Shreyas vuyyuru
287 Reputation
15 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 25
All Time: 25
