Shop the Holiday Gift Guide
No Audio Alerts
Caleb Hoskins and 2 contributors
Last updated on
If your Garmin Drive 53 EX powers on and navigates but fails to produce audible turn-by-turn instructions or proximity alerts, follow this page for possible solutions.
Causes
The system volume may be disabled or set too low to be heard over road noise. To check this, tap the Volume icon on the main menu screen. Ensure the master volume slider is moved to the right (aim for at least 70% for testing) and verify that the Mute checkbox is not selected. Additionally, tap the Wrench icon within the volume menu to ensure "Navigation Phrases" and "Alert Tones" are individually enabled.
2
The Garmin Drive 53 EX might be attempting to send audio to a paired car stereo or Bluetooth headset that is not currently active. To resolve this, go to Settings > Wireless Networks > Bluetooth. If a device is listed as "Connected," disconnect it to restore audio to the internal speaker. You can also test this by turning off Bluetooth entirely on the device to see if sound returns.
3
A software glitch may prevent the audio driver from initializing properly. First, perform a hard reset by holding the Power button for 12 seconds until the device reboots. If the issue persists, connect the device to a computer using a USB cable and run Garmin Express. Check for any "Software Updates" specifically related to system firmware or "Voice Files" and install them to ensure the audio files are not corrupted.
4
If the internal battery is degraded, the device may prioritize GPS tracking over audio amplification to save power. Plug the device into a known working vehicle power cable. If the audio alerts work while plugged in but fail when the device is on battery power, the battery is likely failing. You can follow the Battery Replacement Guide to install a new power cell.
5
If software adjustments do not restore sound, the internal speaker hardware may be blown or disconnected. This is common if the device has been exposed to moisture or extreme heat on a dashboard. To inspect the speaker connections or swap the hardware, please refer to the Owner's Manual.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:14
Past 30 Days:46
All Time:189
