Student In Progress
This wiki is being worked on by hardworking students.
Flydigi Vader 5 Pro bluetooth not connecting
The Flydigi Vader 5 Pro bluetooth is not connecting to the preferred device. Such as the PC, Nintendo Switch, or Android/IOS.
Bluetooth Activation
To activate bluetooth, flip the Bluetooth switch at the back center of the device to the middle option. Then, make sure the device you intend to connect to has bluetooth turned on and is close to the controller.
Enter Pairing mode
To connect the Flydigi Vader 5 Pro to bluetooth make sure you put the controller into paring mode.
  • To put the controller into pairing mode you are going to press and hold the logo(home) button + select + start for about 5 seconds until the light starts to blink rapidly.
  • It is important to note that this device is not compatible with Xbox or PlayStation consoles.
Additional instructions:
Blackgate
Mobile Issues
If the device fails to connect after a few tries, or appears as a mouse while connecting, it may be an issue with the firmware.
  • You may need to update the firmware using the Flydigi game 4.0 software on a PC.
  • Some users have reported that switching to NS mode and connecting using a USB was helpful in triggering the correct firmware update.
  • Another possible solution is using flashplay when playing non-native games.
Additional information from users:
Problem with Flydigi Vader 5 Pro : r/Controller
Clear and reconnect your device
If the controller is still not connecting there could be a problem with the device you are trying to connect the controller too.
  • To fix these problems you could reset your device and turn bluetooth off and on
  • You can go into the settings and forget/unpair an existing profile under the name Xbox Wireless Controller
Nehemiah
51 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 31
All Time: 31
