Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
EasySMX X15 Buttons Activating Without Input
December 20th, 2023 the EasySMX is designed for PC, Switch, IOS, Android
1**. Clean Around the Buttons
-Step 1: Inspect the surface of the controller around the buttons. Look for visible debris such as dust, crumbs, or dirt.
-Step 2: Use a small brush, cotton swab, or compressed air to clean around the edges of the buttons.
-Step 3: Press the buttons several times to check if the cleaning improved their responsiveness.
- Step 4: If the buttons are still sticking, proceed to further cleaning.
2.* Deep Clean with Isopropyl Alcohol
- Step 1: Power off and disconnect the controller.
- Step 2: Dampen a cotton swab with isopropyl alcohol (90% or higher).
- Step 3: Carefully clean the edges and gaps around the sticking buttons. The alcohol will help dissolve grime or sticky residue.
- Step 4: Press the buttons repeatedly while cleaning to help work the alcohol into the button mechanism.
- Step 5: Allow the controller to air dry for a few minutes and test the buttons.
3. *Disassemble the Controller for Internal Cleaning
If surface cleaning doesn’t resolve the issue, you may need to open the controller for a deeper cleaning.
- Step 1: Follow the iFixit EasySMX X15 Controller Teardown Guide to safely disassemble the controller.
- Step 2: Once the controller is open, remove the button assembly.
- Step 3: Clean the internal parts around the buttons with a cotton swab dipped in isopropyl alcohol.
- Step 4: Inspect the rubber membranes under the buttons for wear or damage. If damaged, these may need to be replaced.
- Step 5: Clean the button faces and the contact pads on the controller board to ensure smooth movement.
- Step 6: Reassemble the controller and test the buttons.
4.* Inspect for Liquid Damage
- Step 1: If the controller has been exposed to liquid, there may be sticky residue inside causing the buttons to stick.
- Step 2: Open the controller and carefully clean any dried or sticky residue with isopropyl alcohol.
- Step 3: Ensure all areas are thoroughly dried before reassembling the controller.
- Step 4: Once reassembled, test the buttons to see if the issue is resolved.
5.* Check Button Alignment and Wear
- Step 1: If buttons still stick after cleaning, check that the buttons are properly aligned within their slots.
- Step 2: Inspect the plastic housing and button caps for any warping or wear.
- Step 3: If the rubber button pads (membranes) beneath the buttons are worn out, they may need to be replaced.
- Step 4: Replace any worn or damaged parts, reassemble the controller, and test the buttons.
Preventive Maintenance
To avoid button sticking in the future, follow these simple tips:
-Regular Cleaning: Periodically clean your controller to prevent dust and dirt build-up around the buttons.
- Avoid Liquids: Keep food and drinks away from the controller to prevent accidental spills.
- Use Protective Covers: Consider using silicone covers or button protectors to minimize dirt and debris infiltration.
- Store Properly: Store your controller in a dry, dust-free environment when not in use.
If the issue persists despite these fixes, it may be necessary to replace certain parts like the rubber membrane or button assembly.
0 Comments
