Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Failure To Charge
The device doesn’t charge or the device doesn’t hold its battery.
Faulty Battery
Could need a battery replacement or the problem could be the charging cord. The possible issue is the battery, but try resetting the device first. If this action doesn’t work, then do a battery replacement. You can learn how to do your own battery replacement by following our guide. Replace battery using this guide.
Faulty Power Cord
Test your power cord by trying to charge the device, if it doesn’t charge switch to a second power cord if it charges the cord could be the issue. Possible issue with cord could be fixed by buying a new cord.
Resetting Device
Possible issue could be resolved by powering off the device, then holding the power and home buttons at the same time until the screen lights up. This will reset the device leading to possible resolution of the issue.
Overheating
The device is dangerously hot
Improper usage
The cause of this could be extensive usage during a short period of time or from usage while being on the charger at the same time.
Improper Storage
Another reason could be from not powering off the device before placing it in a bag/carrier.
Minimizing Overheating
Try to avoid using the tablet extensively while charging it. Once device reaches 100% charge remove it. Another possible way to minimize overheating is to make sure to power off the device before placing it into an enclosed carrier.
Frozen Or Unresponsive Screen
The Digiland tablet does not respond to touch; display remains the same.
Resetting Device
Try resetting the device by inserting the end of a paperclip into the port labeled reset and hold for five to ten seconds. This will reset the device and possibly resolve the issue of having a frozen screen.
Faulty screen
If the tablets screen is still not responding after resetting it, the tablet may have a faulty screen and it will need to be replaced.
Weak Or No Wireless Connection
This Digiland tablet is not staying connected to WiFi router.
Check Tablet Settings
Possible issue could be the Wi-Fi is shut off or disconnected in the settings. Go to the settings and double check the Wi-Fi connection.
Resetting Wi-Fi Router
Locate your Wi-Fi router and disconnect it from the source for one minute and then plug it back in and try reconnecting on your tablet
Tablet is not producing sound
Solutions for no sound coming out of device
Bad Headphones
If no sound comes out from the device though your headphones, the problem is likely the headphones. Try another set of headphones to see if the tablet produces sound.
Faulty headphone input/jack
After trying multiple sets of headphones with no improvement on the sound you may have an issue with your input or jack.
connor Bomya
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 616
