Digiland DL1168A Battery Replacement
    1. Digiland DL1168A Battery Replacement, Rear Case: step 1, image 1 of 1
      • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      Ask FixBot
    2. Digiland DL1168A Battery Replacement: step 2, image 1 of 2 Digiland DL1168A Battery Replacement: step 2, image 2 of 2
      • Carefully lift back panel away from the body of the device.
      • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
      Ask FixBot
    3. Digiland DL1168A Battery Replacement: step 3, image 1 of 2 Digiland DL1168A Battery Replacement: step 3, image 2 of 2
      • Desolder the four wires connecting the rear case to the motherboard.
      • Disconnect the wires from the motherboard.
      • Remove the rear case from the device.
      Ask FixBot
    1. Digiland DL1168A Battery Replacement, Battery: step 4, image 1 of 3 Digiland DL1168A Battery Replacement, Battery: step 4, image 2 of 3 Digiland DL1168A Battery Replacement, Battery: step 4, image 3 of 3
      • Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
      • The soldering tool is hot, and will burn. Follow this link for instructions on How To Solder and Desolder Connections.
      Ask FixBot
    2. Digiland DL1168A Battery Replacement: step 5, image 1 of 2 Digiland DL1168A Battery Replacement: step 5, image 2 of 2
      • Using an opening tool, separate the battery from the tablet.
      • Follow the edge of the battery to loosen the glue.
      Ask FixBot
    3. Digiland DL1168A Battery Replacement: step 6, image 1 of 3 Digiland DL1168A Battery Replacement: step 6, image 2 of 3 Digiland DL1168A Battery Replacement: step 6, image 3 of 3
      • Once the glue is loosened, pry the battery away from the screen.
      • Pulling on the battery may cause you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 57
All Time: 712
