Causes
A temporary operating system crash or software freeze can prevent input devices from responding correctly. Even though the device appears powered on, background processes may not be functioning properly.
Solution: Restart the device completely. Hold down the power button until the device shuts off, wait a few seconds, and turn it back on. Once restarted, test the keyboard again to see if normal input has resumed.
If the device has been dropped or handled roughly, the internal ribbon cable connecting the keyboard to the motherboard may have become loose or disconnected.
Solution: Power off the device and inspect the internal keyboard connection. Carefully open the device according to manufacturer guidelines and ensure the keyboard cable is firmly seated in its connector. If the cable appears damaged, it may need to be replaced.
Incorrect system language or keyboard layout settings can cause keys to produce the wrong output or appear unresponsive.
Solution: Open system settings and verify that the correct keyboard language and layout are selected. Adjust the input settings if necessary, then test the keyboard again to confirm that the issue is resolved.
Describe your problem in your own words
