Student In Progress
This wiki is being worked on by hardworking students.
Dell Chromebook 3400 Not Powering On
When attempting to power the Chromebook 3400 but it won't turn on even when plugged into power. This page offers common solutions to this issue
If a Chromebook will not turn on, the issue may be caused by a faulty motherboard, charger, battery, or a completely drained battery. The following troubleshooting steps can help identify the cause of the problem.
System Failure
Inspect the Chromebook to determine why it would not turn on, checking for possible motherboard issues, since a damaged or faulty motherboard can prevent the device from receiving power and starting properly. Along with looking for visible signs of physical damage that could explain the problem.
Faulty Charger
A faulty charger or charging cable may prevent the Chromebook from receiving power.
Inspect the charger: Check the power adapter and charging cable for visible damage or loose connections.
Test the charging connection: Connect the charger to the Chromebook and check whether the charging indicator light turns on.
Try another charger: If possible, use a compatible working charger to determine whether the original charger is faulty.
If the Chromebook turns on with another charger, the original charger may need to be replaced.
Faulty Battery
A damaged or failing battery may prevent the Chromebook from turning on or holding a charge.
Inspect the battery: Check for visible damage. If the battery is damaged, stop using the device and seek professional repair.
Test the battery: If the Chromebook only works while connected to the charger or shuts down immediately after unplugging it, the battery may be failing.
If all else wise fails contact a qualified technician who can test the battery and determine whether it needs to be replaced or visit our device page for additional help
Faulty Motherboard
Check for visible damage: Look for signs of liquid damage, corrosion, or other physical damage.
Check the power : If the Chromebook does not respond to a working charger and a good battery, the motherboard or another internal component may be faulty.
Seek professional inspection: Motherboard diagnosis and repair may require specialized tools and technical expertise.
Device Not Charged
A completely drained battery may prevent the Chromebook from turning on immediately.
Connect the charger: Make sure the charger is securely connected to both the Chromebook and a working outlet.
Allow time to charge: Leave the Chromebook connected for approximately 30 minutes.
Attempt to power on: Press the power button after allowing the device to charge.
If the Chromebook still does not turn on, visit our device page for additional help
0 Comments
