DYMO® LetraTag®
DYMO® LetraTag® label makers are designed for use at home or in the office. Discover the handheld LetraTag® 200B, LetraTag® 100H, LetraTag® 100T and LetraTag® 100H Plus
Miesha B
51 Reputation
0 Guides authored
2 Comments
Please advice, I disassembled the machine, and found a loose spring. I found out that the spring is used to retract the cutter after cutting. But I can't figure out the correct placement of the spring. Does anyone know? It is the handheld version.
Lemonoius - Reply Share
Now I know. Disassemble completely the cutter handle and remove the white part. Then remove the circuit board part from the tape holder. Then the cutter mechanism will come out, and the spring belongs inside the part the blade is fastened to. Use this video to disassemble. https://www.youtube.com/watch?v=UoRt52zM...
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 87
All Time: 896
