Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Drone Won’t Turn on
The drone will not respond or show any sign of powering up
No Battery Life
Your drone may not have any power. This is due to the battery being dead. To correct this issue, plug your charging cable you received with your drone into the drone itself to charge it. Please allow time for the drone’s battery to charge.
Faulty Battery
If the drone does not turn on after charging, the battery may be broken. If this is the case, follow the replacement guide.
Faulty Motherboard
If the first two solutions did not work, it may be an issue with the internal wiring or the motherboard. you can view our replacement guide on the motherboard for additional details.
Tablet/Phone Not Connecting to Drone
The drone is not connecting to your divide of choice
Faulty Cable
There may be an issue with the wiring in your connecting cable. If this is the case, you will need a replacement wire, which you can reach out to DJI for assistance or purchase a new cable at the link: ++https://store.dji.com/product/mavic-ai...
App issue
A possible issue could be a problem with the DJI Fly app. Check to see if there are any recent updates for the app by going into your device's app store, finding the app, and then checking the version history and comparing it to the most recent version. If there are no updates, or this does not solve the issue, try to reinstall the app by deleting it and then download it again through your device's app store .
Device Not Supported
The device you are using to connect to the drone may not be supported. If this is the case, you will need to use a new device. You can find a list of compatible devices here: ++https://cultofdrone.com/dji-fly-compat...
Controller Not Connecting to Drone
The drone is not recognizing the controller
Controller has no Power
Your controller may not have any battery life. Plug in the controller with the provided cable to recharge the controller.
Incorrect Version of App
Similar to the above, check to see if there are any recent updates for the app by going into your device's app store, finding the app, and then checking the version history and comparing it to the most recent version. If there are no updates, or this does not solve the issue, try to reinstall the app by deleting it and then download again through your device's app store .
Faulty Motherboard
If there are no physical signs of damage or the above didn’t work, there may be an internal issue with your controller. To fix this, disassemble the controller and replace it with a new one.
Random Beeping From the Controller
The controller is making a constant beeping sound
App needs Update
There may be an issue with the DJI Fly app. Check to see if there are any recent updates for the app by going into your device's app store, finding the app, and then checking the version history and comparing it to the most recent version. If there are no updates, or this does not solve the issue, try to reinstall the app by deleting it and then downloading it through your device's app store .
Sticks not Centered
The beeping may occur from the sticks not being centered. To solve this, move the sticks around repeatedly on your controller to see if the beeping ceases.
Faulty Controller Motherboard
If there are no physical signs of damage or the above didn’t work, there may be an internal issue with your controller. The motherboard may need to be replaced.
7 Comments
Hey! This is an Excellent guide for troubleshooting a DJI drone! However, I think you should consider adding a troubleshooting spot for the motors/gimbal. I think that would make this amazing guide, even more top tier!
Joseph Clapp - Reply
I having gimbal errors is it trash after that
juarus - Reply
My mavic air2 remote control is not turning on and either not getting charged 🥹please help
Vikram - Reply
You can also try These tips if your DJI drone doesn't turn on check the link and read the full article
Dartimes Tv - Reply
Dji mavic air 2 status LEDs do not turn on when I switch the drone on, what could be the problem?
Allan Traps - Reply
