Student In Progress
This wiki is being worked on by hardworking students.
BOOX Palma 2 Screen Not Refreshing
The BOOX Palma 2 Screen is not refreshing. This page includes some common issues, and their solutions.
Battery is Discharging volts or has very Low Voltage
  • Avoiding full depletion: Plug in the device before it drops to 0% to prevent discharge stress on the internal battery
Force a restart: If the device is unresponsive and or not turning on hold power button for 10-15 seconds to force a hard reboot
Extreme Ambient Temperatures
  • Charge: Avoid using high-wattage fast chargers like 67W laptop blocks, use a standard lower-wattage charger instead.
Background Apps: close out of third party browsers or readers that may be stuck in a loop.
Software Bugs or Sensor Malfunctions
  • Occasionally, a software glitch or a faulty reading from the device's internal thermal sensor can trigger a false positive alert.
perform a full restart to clear any stuck system tasks or software loops that might be overworking the processor.
Corrupted MicroSD Card or High I/O Stalls
  • Reformat the card on a computer to exFAT or run a disk repair scan like CHKDSK to fix corrupted sectors.
  • To repair bad sectors and file system errors on your microSD card, run a file systems repair check. Insert it into a computer, open Command Prompt as an administrator, and run the command chkdsk X: /f /r. You would replace X with your card’s drive letter.
Animation Filter Mismatches
  •  When an app pushes a continuous 60-fps animation stream, the BOOX Super Refresh (BSR) engine struggles to keep up.
  •  Long-press the app icon, go to Optimize, and increase the Animation filter time (safest between 20–30 or longer) to force the system to ignore minor UI animations.
Brody Vandling
152 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 29
All Time: 29
