Student In Progress
This wiki is being worked on by hardworking students.
Poor Airflow
Clean the fans of any debris, as excessive dust buildup reduces cooling efficiency. Use the device on a flat surface that allows proper airflow to all vents, especially those on the bottom of the device. Using the device on a pillow or soft surface that completely covers the air vents could result in reduced cooling capability.
High CPU Load
Reduce CPU load by closing programs or stopping downloads.
Check if the CPU is under unusual load by pressing the Search + Esc button to open the Chrome OS task manager and check for high-usage programs and then close the programs.
Outdated Chrome OS
A software update can fix overheating issues by resolving buggy programs that are using too many CPU cycles.
First, connect to the internet, click the time in the bottom-right corner, then click Settings. In Settings, click About ChromeOS, then click Check for Updates.
Faulty Battery
If all else fails, a battery replacement might be needed. It can cause the system to become unstable. Follow >>this guide<< to replace the battery in the Asus Chromebook Vibe CX5501 Flip.
Moses Tarula
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 46
All Time: 46
