Up to 20% off select tools
ASUS Chromebook Flip C214MA Screen Is Unresponsive
Miguel Soriano and 1 contributor
Last updated on
The ASUS Chromebook Flip C214MA screen does not respond to touch input or appears frozen. The display may turn on normally, but tapping, swiping, or using gestures has no effect. In some cases, the cursor may still move using the trackpad or mouse, while touch functionality remains inactive. This issue may be caused by software glitches, touchscreen driver errors, physical damage, internal cable disconnection, or motherboard failure.
Causes
Temporary Software Glitch
ChromeOS can occasionally freeze, causing the touchscreen to stop responding even though the device appears powered on.
Hold down the Power button for 10 seconds to force the Chromebook to shut down. Wait 15–20 seconds, then power it back on.
If the screen works normally after rebooting, the issue was likely a temporary system freeze.
Touchscreen Disabled in Settings
ChromeOS allows certain input features to be disabled through system flags or accessibility settings.
Restart the Chromebook and log in. Open Chrome and type chrome://flags into the address bar. Search for “touchscreen.” Ensure that touchscreen-related features are not disabled.
If you recently enabled developer mode or changed system settings, revert those changes and restart the device.
Outdated or Corrupted ChromeOS
System software corruption can prevent proper touchscreen functionality.
Connect the Chromebook to Wi-Fi.
Go to Settings → About ChromeOS → Check for updates.
Install any available updates and restart the device.
If the issue persists, perform a Powerwash (factory reset):
Back up your files.
Go to Settings → Advanced → Reset settings → Powerwash.
Follow the prompts to reset the device.
If the touchscreen still does not respond after a factory reset, the issue is likely hardware-related.
Loose or Disconnected Display Cable
The display assembly connects to the motherboard via internal ribbon cables. If the device has been dropped or opened previously, the touchscreen cable may be loose.
Power off the device.
Remove the back cover using the appropriate screwdriver.
Carefully inspect the display and digitizer ribbon connections on the motherboard.
Reseat any loose cables and ensure they are fully secured.
If you are unsure how to access the internal components, refer to:
Asus Chromebook Flip C214MA Display Assembly Replacement
Damaged Touchscreen Digitizer
If the screen is cracked, has dead zones, or only responds intermittently, the digitizer may be damaged.
Inspect the glass for cracks or pressure marks.
Test multiple areas of the screen to see if certain regions respond.
If only specific sections are unresponsive, the digitizer has likely failed and will need replacement.
Refer to:
Asus Chromebook Flip C214MA Trackpad Replacement
If no visible damage is present and all other causes have been ruled out, replacing the motherboard may be required.
Refer to:
[Asus Chromebook Flip C214MA Motherboard Replacement
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:9
Past 30 Days:43
All Time:196
