Shop the Holiday Gift Guide
Audio Has Unbalanced Sound
Elias Mireles and 1 contributor
Last updated on
If your Alienware AW510H is producing unbalanced sound, follow this page for possible solutions.
Causes
Before diving into settings, rule out hardware hiccups first.
  • Reseat the Cables: The AW510H has a detachable cable system. Ensure the cable is pushed completely into the headset ear cup — even a millimeter out will drop a channel. Also confirm it's fully seated in the device.
  • USB DAC vs. 3.5mm: If using the USB dongle, try a different port (preferably a rear port on a desktop). Then try bypassing the dongle entirely with the 3.5mm splitter. If sound is balanced over 3.5mm but not USB, the dongle is the culprit.
  • Inline Volume Wheel: The physical volume slider on the cable can get stuck between contacts and cause one side to dip. Scroll it up and down rapidly to clear dust or static.
2
Windows occasionally stores a volume offset for specific devices.
  • Press Win + R, type mmsys.cpl, and hit Enter.
  • In the Playback tab, right-click your Alienware AW510H and select Properties.
  • Go to the Levels tab and click Balance.
  • Confirm both L and R are set to the same value (e.g., 100).
3
The AW510H relies heavily on AWCC for its 7.1 Virtual Surround sound processing.
  • Disable Audio Effects: Open AWCC, go to the Fusion tab (thermometer icon), and select the Audio section. Turn off all Smart Echo, Bass Boost, and Reverb effects to check whether a software profile is causing the imbalance.
  • Reinstall the Driver:
    • Right-click the Start button and select Device Manager.
    • Expand Sound, video and game controllers.
    • Right-click Alienware AW510H Gaming Headset and select Uninstall device.
    • Unplug the headset, restart your PC, and plug it back in. Windows will reinstall a clean driver automatically.
If none of the above resolve the issue, refer to the Alienware AW510H guide.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:19
Past 30 Days:69
All Time:194
