Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Trackpad won't Work
The trackpad is not responding to my touch.
Hardware Issue is Causing the Trackpad to Not Work
To test that the trackpad itself is not at fault:
Make sure there is no dust or dirt on the touchpad. If this doesn't work, drumroll your fingers on the touchpad for ten seconds to make sure any potential interferences with connection of the trackpad (like dirt) are gone.
Software Issue is Causing the Trackpad to Not Work
Take the following steps in order until one of them solves the issue:
Touch the Esc key several times. Turn your Chromebook off, then back on again. If these do not work, you might need to perform a hard reset.
Trackpad Works for Some Accounts but Not Others
If you have more than one account on your Chromebook, delete the account that has problems with the touchpad, then re-add the account.
Faulty Trackpad
If there are continual problems with your trackpad that the above steps do not help, your trackpad may be at fault. Follow the Trackpad Replacement Guide to replace your trackpad.
Chromebook Won't Turn On
My chromebook won't turn on even though I charged it overnight.
Computer Needs a Reboot
If the computer will not begin to boot, a hard reset may be needed to get the computer back up and running. A hard reset will not delete any files nor act like a Restore. To do this: Turn the Chromebook off, hold down the Refresh button (circular arrow at top of the keyboard) and the Power button simultaneously for about 5 seconds. Release the buttons and the computer should restart.
Computer Won't Charge
The battery or charger may be the problem. See the below "Chromebook Battery Won't Charge" section to see troubleshooting steps for this issue. If this does not work, continue to the "Hard Drive Issue" subsection.
When I plug the charger into the Chromebook, it doesn't charge the battery.
The Charger is Broken
If you have access to another Chromebook charger, plug it into your laptop. If your Chromebook charges, then your charger is broken and you must replace it. If your Chromebook still doesn't charge, the battery is most likely the issue. An important note, however, is to be sure to try both chargers from different wall sockets, because the true issue could be with where you're charging it from!
The Chromebook Battery is Bad
If the above steps do not work, your battery may be faulty, and needs to be replaced. Follow the steps in the Battery Replacement Guide.
Hard Drive Issue is Preventing Charging
If your Chromebook still doesn't charge, perform a hard reset. If this doesn't fix it, you may need to replace the hard drive.
Screen is Frozen
Screen is frozen and computer won't respond or turn off.
Running Program is Causing the Freeze
The program that is running on your Chromebook may be causing it to slow down and display a frozen screen. Close the program by force quitting or by pressing the escape button.
Software Issue is Causing the Freeze
If the computer is frozen and will not follow any commands or turn off, you may need to perform a hard reset in order to restore your computer. To do this, simply press and hold the refresh button (circular arrow button at top of the keyboard) and the power button for about 5 seconds, or until the computer begins to reset. If this does not work, unplug your computer from the charger and allow the battery to die. After about three hours, reconnect it to the charger and turn the computer on.
Hardware Issue is Causing the Freeze
If there is anything plugged into your laptop through the charging port, USB, or audio jack, unplug it temporarily, as this may be the cause of your frozen screen. Once your screen goes back to normal, you can plug your hardware back in.
"OS is Missing or Damaged" Error
The screen displays "OS system is damaged or missing."
Battery Issue is Causing Error Message to Appear
If the Chromebook dies after this error occurs, plug into charger and allow the dead battery to fully recharge overnight before attempting to restart.
The Operating System is Not Working Properly
If turning your Chromebook off and on again doesn't work, you may need to recover your Chromebook. Note that recovery permanently erases everything on your Chromebook's hard drive, including your downloaded files, so be sure to back up your files before performing a recover. Follow these steps to recover your Chromebook.
System Errors
My Chromebook is shutting down often
Chromebook is shutting down unexpectedly
If your Chromebook is shutting down frequently your best option is to shut down your Chromebook and let it rest for a few minutes. If that does not work it may be a website or extension that you use frequently that is the issue.
Removing an extension
To remove an extension go into the chrome browser, click on the three-dot icon in the upper right corner, select the more tools in the drop list, select extensions and remove any unwanted extensions that may be causing the issue.
Sound Won’t Work on Chromebook
I can’t hear anything on my Chromebook
Unable to hear sound
Before adjusting the sound it’s important to make sure headphones are disconnected before trying to play any sound through speakers and if the use of an audio device such as an external speaker is connected that it’s working properly. Once you’ve analyzed those details you can continue to find the system clock located in the right bottom corner and adjust the volume slider displayed on the pop-up menu and turn it up high enough to hear.
The sound input and output
If the above steps don’t work you can also change the sound input or output by clicking the system clock located at the bottom corner then click the arrow displayed next to the volume slider on the pop-up menu. This icon won't appear if you do not have external sound devices connected to your Chromebook. It’s important to notice whether the pop-up menu has the correct audio device set as your output and if this doesn’t work you should consider rebooting the Chromebook following the above steps again.
When Applications are Open, Computer Slows Down
While web browsing, my computer slows down tremendously
This may be attributed to the high RAM usage of some apps, like Chrome, and the small RAM availability of the computer. You may need to close other open and active programs using the Task Manager. To do this you will need to press the Search + Esc buttons in order to open the menu. From here, select and close apps by clicking End Process. Close any apps that you are currently not using or that are running in the background that you may not even know that you had running.
Even after closing open apps, the computer still runs slow
If the Task Manager fix does not help resolve the issue, you may need to upgrade the RAM in the laptop which will be a replacement of the factory memory that is in the computer. You will need to consult a computer technician or buy and install a RAM upgrade kit from an online seller for your specific model.
Tiana Ton Nu
118 Reputation
0 Guides authored
Cal Poly, Team S15-G1, Banghart Spring 2017 Member of Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Members
72 Guides authored
53 Comments
My Acer chromebook 15 wont turn on , the charger is plugged in but the light don’t turn on. I know the charger works cause it charges other chromebooks but not mine . I tried the power and the restart button trick but it doesn’t work
Daileni - Reply Share
Did you resolve this issue be a use I'm having the same issue right now.. Tried to do a hard reset but bone of the buttons are doing anything. The screen is just black but it was on a charged up a few hours ago. Now when I plug in the charger.. The light won't even turn on to tell me its charging
Joseph Green - Reply Share
Could be your charger port too. If the charger is loose in the port it may need to be fixed. Mine did that in my Samsung chrome book. Not good.
P Morris - Reply Share
When the keyboard and touchpad are not responsive, for who knows how long, try plugging a memory card or drive, or phone, or camera, or whatever, into an appropriate USB port or SDcard slot - mine did some visual grumbles and was back to working immediately. Out of caution, I did do a shutdown and restart as soon as I confirmed I wasn’t losing anything.
Alan Winston - Reply Share
I tried to hard reboot my laptop but the light that shows that it's on only turns on for a second and turns off like it does when I try to turn it on normally I need help. the light that shows the battery is charging works fine
ErickNavarrete - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 40
All Time: 109,688
