Causes
Solution: Close tabs you aren’t actively using and quit web apps you don’t need right now. If Chrome has been running for a long time, restart the Chromebook to clear stuck processes and free memory so pages can load and render normally again.
Solution: Identify the tab that is spiking CPU/memory and close it, especially pages with auto-playing video, heavy ads, live dashboards, or constant refreshing. If you’re not sure which tab is causing it, open Chrome’s Task Manager and end the specific tab/process that’s using unusually high resources which you can gauge by looking at memory or CPU %. Task_Manager_Tutorial
Solution: Disable extensions you don’t need (especially ad blockers, coupon tools, download helpers, security scanners, and layout/theme modifiers primarily) then test loading speed again. If performance improves, reenable extensions one at a time to find the slow one and remove or replace it Remove_Chrome_Extensions
Solution: Update Chrome so extensions run on the latest browser version, then remove duplicate extensions that do the same job, for example multiple ad blockers or multiple privacy tools. Conflicting extensions can repeatedly scan or write to pages, which slows loading and causes rendering glitches.
Solution: Free up storage by deleting large downloads, removing unused apps, and clearing offline files you don’t need, then clear Chrome’s cached files so the cache can rebuild cleanly. Keep a healthy buffer of free space so Chrome can store cache and temporary data without constantly purging and rebuilding it. Chromebook_Clean_Storage
Describe your problem in your own words
