Introduction
Once upon a midnight dreary, while we pondered, weak and weary, over many quaint and curious volumes of service manual lore—while we pondered, nearly napping, suddenly there came a tapping, as of some one gently rapping, rapping at our teardown door.
“’Tis some pumpkin,” we did mutter, “rapping at our teardown door—
Only this and nothing more.”
Pumpkin: this fall's must-have device. Despite a yearly release cycle, our Late 2016 Pumpkin doesn't sport any major upgrades from last year's model.
Here're some specs on Pumpkin:
Pumpkin comes in several stunning finishes: Really Orange, Space Orange, and Annoying Orange. Jet Orange is currently sold out.
This model is marketed primarily as decorative, lacking the necessary features (e.g. heat sensitive material) for models used in pie-making.
No operating system is required
Time to disconnect the battery.
We've said it before, we'll say it again: integrated, difficult-to-replace batteries are spooky. We're pleased this Pumpkin-maker made the battery easy to access.
This long-lived battery will have enough pumpkin juice to make it all night—or at least until the Great Pumpkin comes.
Pumpkin's spherical unibody design is something of a novelty—the last time we saw anything like this was Google's Nexus Q.
Getting in will prove challenging, as the seams on the outside appear to be purely decorative. And there's not a screw in sight. This thing is locked up tighter than Dracula's castle.
Before we resort to invasive tactics, we heat up our iOpener to soften up any hidden adhesive that might be lurking under the handle. But Pumpkin keeps mum.
We were hoping to avoid smashing pumpkins, but it looks like we're going to have to bust our way in. A top-down approach seems most intuitive.
We start by carefully plotting out a path of entry. We don't want to damage any internal components that may be hiding under the handle.
Tool used on this step:Jimmy$7.95
Peter, Peter, pumpkin-eater couldn't breach this orange shell. Instead we tried our Jimmy—and it worked out very well.
Usually, we use the Jimmy for prying. But we're going full Michael Myers and using the Jimmy to stab Pumpkin open.
Even with a convenient handle, the lid is difficult to remove. A mystery adhesive underneath is too strong for our suction cup. And that just sucks.
So we break out our spudger. Jamming it under the lid seems to do the trick(-or-treat).
Grasp Pumpkin firmly by the handle.
After a decent tug, the lid comes free from the device, trailing an adhesive residue after it. We haven't seen this much adhesive gunk since we took apart the Surface Pro.
Ripping the
headlid off proves to be a bit of a nightmare. -
We raise this Pumpkin-top like the dead, anxious for a little
grave robbingpie makinginvestigation of its fleshy, vascular strands.
Tool used on this step:Tweezers$4.99
Now comes the delicate process of removing the internal components. We reach our tweezers into the unexplored depths of Pumpkin and pull out an ...
iPhone headphone jack assembly! So that's where Apple put them all.
With that out of the way, we start removing the other components ... one by one. This is gonna take awhile.
Here's what we like about Pumpkin—there's no walled garden (unless you literally grow Pumpkin in a walled garden). When it comes to hardware—this sucker is fully moddable!
We start by affixing a stencil to Pumpkin's outer case, and to "stay in the lines," so to speak, we do a little tracing too.
With this many pins in it, Pumpkin is shaping up to be a real Hellraiser.
We didn't find our favorite screw-type in Pumpkin, so we're going to put it on Pumpkin.
A tech knife is all it takes to excise the cross-head.
Scoring Pumpkin requires a more specialized tool. The scorer allows us to scrape away the hard, outer-layer of orange, revealing a softer, lighter material underneath.
Some models of Pumpkin come with a heating element preinstalled—but our base model didn't include one. Guess we'll just have to upgrade.
Good thing we've still got this handy fuel source! Once it spontaneously combusts, that 13.48 Wh battery will be just the thing to light Pumpkin up like the Fourth of July.
Don't mind that smell, it's operating as designed. The flavor has proven to be very popular with modern consumers.
Uh-oh. This Pumpkin completely lost its head! Thanks to our friends at Creative Electron for popping Pumpkin into their spooktacular X-ray machine and sharing the results with us.
37 Comments
How do I reassemble?
Facile : il suffit de planter une graine...
paddy -
There is no reassembly. But you can replicate by planting one of the excavated seeds.
