Introduction
Riding a bike is a great thing, but occasionally you can get a flat tire. Flat tires can be caused by rocks, debris or just plain wear and tear. This can puncture the tire which in turn creates a hole in the inner tube that needs to be repaired. This repair guide will easily teach anyone how to patch a hole in their bicycle tube. After patching your bike, you will be ready to go!
Using the tire lever hook side, hook the inside of the tire. Then proceed to remove the first side of the tire from the rim all along the circumference of the rim.
Once one side is out, pull the rest of the tire out in the same direction.
Grind the location of the hole slightly until the surface feels a little rough.
Next, apply a thin coat of the rubber cement around the hole. The coat of cement should be about the same size as the patch.
For best results wait until the rubber cement is dry to the touch—around three minutes.
Finally, peel off the back of the patch, place it over the area of rubber cement with the hole centered, and then apply pressure with thumb until rubber cement is dry.
Now that the tire's tube has been patched, all that is left is to place the tire back onto the bike, lock it in, re-inflate it, and the bike is ready for a joy ride. Enjoy.
10 other people completed this guide.
