This teardown is not a repair guide. To repair your Acer Optical Mouse, use our service manual.
  1. Acer Optical Mouse Teardown, Gather Items: step 1, image 1 of 1
    • Lay out your mouse and gather your tools.
  2. Acer Optical Mouse Teardown, Remove sticker: step 2, image 1 of 1
    • Use metal spudger to lift sticker
  3. Acer Optical Mouse Teardown, Unscrew: step 3, image 1 of 1
    • Using a phillips #0, unscrew the screws
  4. Acer Optical Mouse Teardown, Lifting the lid: step 4, image 1 of 1
    • Applying some force lift the mouse top up and backward at the same time to disconnect it
  5. Acer Optical Mouse Teardown, Remove scroll wheel: step 5, image 1 of 1
    • Once inside pull on the scroll wheel to remove it from the board
  6. Acer Optical Mouse Teardown, Remove motherboard: step 6, image 1 of 1
    • Pull on the cable and the board should come out
  7. Acer Optical Mouse Teardown, Remove plastic: step 7, image 1 of 1
    • Then pull out the plastic at the bottom
  8. Acer Optical Mouse Teardown, All done: step 8, image 1 of 1
    • All done just follow guide in reverse to reassemble
Oduelca
187 Reputation
1 Guide authored
2 Comments
The wireless version of this mouse has 2 extra screws under the other two small pads and arranged differently because of the battery compartment intrusion into available space. There was also a small screw retaining the circuit board.
Terry Ess - Reply
Scroll not working
Nimai Padhy - Reply
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 119
All Time: 3,299
