This teardown is in progress – Reload periodically to see the latest changes!
  1. Vornado Zippi Fan Teardown, Removing Stand: step 1, image 1 of 3 Vornado Zippi Fan Teardown, Removing Stand: step 1, image 2 of 3 Vornado Zippi Fan Teardown, Removing Stand: step 1, image 3 of 3
    • Pull the stand out of the enclosure on each side
  2. Vornado Zippi Fan Teardown, Remove Blades and Speed Control: step 2, image 1 of 3 Vornado Zippi Fan Teardown, Remove Blades and Speed Control: step 2, image 2 of 3 Vornado Zippi Fan Teardown, Remove Blades and Speed Control: step 2, image 3 of 3
    • Remove the blades by pulling away from the enclosure
    • Remove the speed control by pulling away from the enclosure
  3. Vornado Zippi Fan Teardown, Remove Guard Screws: step 3, image 1 of 2 Vornado Zippi Fan Teardown, Remove Guard Screws: step 3, image 2 of 2
    • Remove the 4 screws coupling the orange plastic enclosure and black plastic guard
  4. Vornado Zippi Fan Teardown, Remove Enclosure Screws: step 4, image 1 of 3 Vornado Zippi Fan Teardown, Remove Enclosure Screws: step 4, image 2 of 3 Vornado Zippi Fan Teardown, Remove Enclosure Screws: step 4, image 3 of 3
    • Remove the screw coupling the top half of the enclosure
    • Remove the screw coupling the bottom of the enclosure, near the power cable
    • Remove the screw beneath the rubber inserts holding the stand
  5. Vornado Zippi Fan Teardown, Remove Enclosure and Guard: step 5, image 1 of 3 Vornado Zippi Fan Teardown, Remove Enclosure and Guard: step 5, image 2 of 3 Vornado Zippi Fan Teardown, Remove Enclosure and Guard: step 5, image 3 of 3
    • Separate the two halves of the enclosure, leaving the power cable, switch, motor and guard
    • Remove the 2 screws attaching the guard to the motor
  6. Vornado Zippi Fan Teardown, Remove Switch: step 6, image 1 of 2 Vornado Zippi Fan Teardown, Remove Switch: step 6, image 2 of 2
    • Remove the 2 screws holding the switch in the mount connected to the motor
  7. Vornado Zippi Fan Teardown, Remove Switch Mount: step 7, image 1 of 2 Vornado Zippi Fan Teardown, Remove Switch Mount: step 7, image 2 of 2
    • Remove the two screws securing the switch mount to the motor
Nathan Lentz
20 Reputation
1 Guide authored
2 Comments
Mine was making noise and difficult to get the nose cone pulled off. I used two coins in the crack on opposing sides and twisted them.
S Lewis - Reply
it won't keep it`s position ,folds and flaps out ,if i could tighten the arm
andre b - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,152
