Introduction
One of the latest phones from RIM, dubbed the Blackberry Bold 2, the 9700 is the first Blackberry to sport a trackpad.
Other notable features new in this phone are a built-in threaded SMS app, an autofocus camera and an LED flash.
Onyx is RIM's Codename for the Bold 2
For more information take a look at this guide.
Alright, lets get started. Make sure you turn the phone completely off before you begin.
Alright, lets get down to the fun stuff.
Using the plastic opening tool, pry off the small plastic strip that rests under the keyboard. Once it is loose enough pull it up using your fingers.
When prying around the strip by the keyboard, be careful not to pull up on the keyboard keys by mistake.
Take your prying tool and insert it between the LCD and silver trim.
Work your way around the whole device making sure to apply some pressure, but not too much as the plastic is very flexible.
Once you have the trim released, lift from the bottom of the phone and push the whole piece towards the top of the phone.
It is all one big piece so the section covering the lock and mute button should come off together.
Now we remove the mainboard. first you must disconnect the ribbon connector at the top.
Lift the board up near the top of the phone and slide it away from the bottom of the phone. It should come out pretty simply.
Some of the tactile buttons may fall out form the side. That is okay, just make sure you don't loose them.
