Teardown of IBM ThinkPad i Series 1200
  1. Teardown of IBM ThinkPad i Series 1200, Drums: step 1, image 1 of 1
    • Before beginning, ensure the notebook is powered off.
    • Unplug the power cord.
    • To remove it, slide the two switches in such a way that it is unlocked, as shown in the picture, and then remove it.
  2. Teardown of IBM ThinkPad i Series 1200, HDD (Hard Drive): step 2, image 1 of 2 Teardown of IBM ThinkPad i Series 1200, HDD (Hard Drive): step 2, image 2 of 2
    • Remove the screw in the lower corner.
    • Remove the "cover" of the disk.
    • Pull the "hook" that is attached to the disc to remove it.
  3. Teardown of IBM ThinkPad i Series 1200, RAM cover: step 3, image 1 of 2 Teardown of IBM ThinkPad i Series 1200, RAM cover: step 3, image 2 of 2
    • Remove the indicated screw from the backside of the notebook.
    • Take off the cover that protects the RAM memory.
  4. Teardown of IBM ThinkPad i Series 1200, Keyboard: step 4, image 1 of 1
    • Open the screen and lay it off the side in a flat manner.
  5. Teardown of IBM ThinkPad i Series 1200: step 5, image 1 of 1
    • Remove the indicated screws on the backside of the PC.
  6. Teardown of IBM ThinkPad i Series 1200: step 6, image 1 of 1
    • Slide the keyboard down so that the covers from above aren't blocked and as so we will be able to remove them more easily.
    • Don't pull too hard as this can cause the flex cables to break.
    • Disconnect the two ribbon cables that are located on the underside of the keyboard.
    • The back up battery will be connected on the upper middle part.
  7. Teardown of IBM ThinkPad i Series 1200, Internal RAM: step 7, image 1 of 1
    • Remove the three indicated screws from the backside.
    • It is to be note that these screws are located under protective rubber caps.
  8. Teardown of IBM ThinkPad i Series 1200: step 8, image 1 of 1
    • Remove the RAM compartment.
  9. Teardown of IBM ThinkPad i Series 1200, Ethernet card: step 9, image 1 of 2 Teardown of IBM ThinkPad i Series 1200, Ethernet card: step 9, image 2 of 2
    • Remove the two indicated screws.
    • Remove the metal protector that is found above the plate.
  10. Teardown of IBM ThinkPad i Series 1200: step 10, image 1 of 1
    • Remove the Ethernet card.
    • Careful as there's a cable connected that can be accidentally broken.
  11. Teardown of IBM ThinkPad i Series 1200, Optical drive: step 11, image 1 of 2 Teardown of IBM ThinkPad i Series 1200, Optical drive: step 11, image 2 of 2
    • Remove the indicated screws from the backside of the PC.
    • Remove the optical drive by simply sliding it out.
  12. Teardown of IBM ThinkPad i Series 1200, Display: step 12, image 1 of 1
    • First, remove the plastic components indicated.
    • These components are press-fitted, and thus we will have to remove them with care.
    • Remove the two screws that are found after step one.
    • Remove the plastic protector that is found on the upper part.
  13. Teardown of IBM ThinkPad i Series 1200: step 13, image 1 of 2 Teardown of IBM ThinkPad i Series 1200: step 13, image 2 of 2
    • Proceed by removing the two connectors that are found there.
    • Carefully start separating the display from the inferior side of our PC.
  14. Teardown of IBM ThinkPad i Series 1200, CPU: step 14, image 1 of 2 Teardown of IBM ThinkPad i Series 1200, CPU: step 14, image 2 of 2
    • Remove the plastic frame that surround the netbook.
    • This component is press-fitted, so you have to remove it carefully so it doesn't break.
    • Remove the metallic protector.
    • Put aside the CPU cooler.
  15. Teardown of IBM ThinkPad i Series 1200, Thermic paste change: step 15, image 1 of 2 Teardown of IBM ThinkPad i Series 1200, Thermic paste change: step 15, image 2 of 2
    • Clean the fan and the old CPU paste.
    • You have to use alcohol and a small tissue.
    • Alcohol is to not be used on any other part that was that aforementioned.
  16. Teardown of IBM ThinkPad i Series 1200: step 16, image 1 of 1
    • Place new thermic paste and start putting your PC back together.
  17. Teardown of IBM ThinkPad i Series 1200, Dismantling the dislpay.: step 17, image 1 of 2 Teardown of IBM ThinkPad i Series 1200, Dismantling the dislpay.: step 17, image 2 of 2
    • Once step 13 is completed.
    • Remove the plastic covers that surround the display.
    • It must be done with a guitar "pick" as the plastic covers could break or scratch.
  18. Teardown of IBM ThinkPad i Series 1200: step 18, image 1 of 2 Teardown of IBM ThinkPad i Series 1200: step 18, image 2 of 2
    • Remove the indicated screws that hold the led board.
  19. Teardown of IBM ThinkPad i Series 1200, Inverter: step 19, image 1 of 3 Teardown of IBM ThinkPad i Series 1200, Inverter: step 19, image 2 of 3 Teardown of IBM ThinkPad i Series 1200, Inverter: step 19, image 3 of 3
    • Remove the indicated screws that hold the metallic covering.
    • Underneath you will find the inverter.
  20. Teardown of IBM ThinkPad i Series 1200: step 20, image 1 of 1
    • Power supply connectors from motherboard to inverter.
    • Data cables from motherboard to display.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Gianfranco Grigera
301 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 239
