This teardown is not a repair guide. To repair your Sony Ericsson Xperia X10 Mini E10i, use our service manual.
  1. Sony Ericsson Xperia X10 Mini E10i Teardown, Sony Ericsson Xperia X10 Mini E10i Teardown: step 1, image 1 of 2 Sony Ericsson Xperia X10 Mini E10i Teardown, Sony Ericsson Xperia X10 Mini E10i Teardown: step 1, image 2 of 2
    • The Sony Ericsson Xperia X10 Mini E10i is the smaller version of the Sony Ericsson Xperia X10.
    • Tech Specs:
    • 600 MHz Qualcomm MSM7227
    • 256 MB RAM and 256 MB internal ROM (only 128 MB accessible)
    • 2.6" color transflective TFT display with a resolution of 240 X 320 pixels.
    • 5 Megapixel camera with autofocus
    • 802.11 b/g Wireless + Bluetooth 2.1
    • The backside of the X10 Mini E10i is characterized by a smooth plastic rear case with openings for the camera, LED flash, and speaker.
  2. Sony Ericsson Xperia X10 Mini E10i Teardown: step 2, image 1 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 2, image 2 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 2, image 3 of 3
    • The controls of the X10 Mini E10i are pretty standard.
    • The bottom of the X10 Mini E10i integrates a 3.5 mm headphone jack as well as a micro-USB port.
    • The top edge houses the power button.
    • The left side accommodates the volume and camera buttons, leaving the right side blank and featureless.
  3. Sony Ericsson Xperia X10 Mini E10i Teardown: step 3, image 1 of 2 Sony Ericsson Xperia X10 Mini E10i Teardown: step 3, image 2 of 2
    • The 5.0 megapixel camera in the X10 Mini E10i features a 1X optical zoom with autofocus and a built-in LED flash.
    • The camera itself measures in at 8.8 x 9.1 x 6 mm.
  4. Sony Ericsson Xperia X10 Mini E10i Teardown: step 4, image 1 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 4, image 2 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 4, image 3 of 3
    • A few quick pries with an iPod opening tool around the perimeter of the X10 Mini E10i and the rear case easily pops off to access the phone's innards.
    • The actual electronic volume and camera buttons are attached directly to the logic board. The buttons you press on the outer case are just chrome covers.
  5. Sony Ericsson Xperia X10 Mini E10i Teardown: step 5, image 1 of 1
    • A thumbnail is all that is needed to remove the microSD card from its housing in the inner case.
    • The simple design of the Mini E10 allows most components to plug directly into the logic board. The only exception is the external microSD card slot.
    The external card slot is microSD not SIM.
    Radha Santadharma - Reply
  6. Sony Ericsson Xperia X10 Mini E10i Teardown: step 6, image 1 of 2 Sony Ericsson Xperia X10 Mini E10i Teardown: step 6, image 2 of 2
    • A single T5 Torx screw and a few plastic clips are all that secure the antenna assembly to the inner case.
    • The antenna assembly uses simple yet effective pressure contacts to make a connection with the logic board. No connectors necessary!
    remember to take out the bottom two screws
    Sven Frenzel - Reply
    Step 6, Can I buy somewhere the Antena or just that part.. My friend lost it xD
    Ado Extasy - Reply
  7. Sony Ericsson Xperia X10 Mini E10i Teardown: step 7, image 1 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 7, image 2 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 7, image 3 of 3
    • A couple more T5 Torx screws secure the rear inner case and logic board to the rest of the X10 Mini E10i.
    • Disconnect the battery connector from the logic board with the flat end of a spudger.
    • Pry up the SIM card socket connector and remove the rear inner case from the the logic board.
  8. Sony Ericsson Xperia X10 Mini E10i Teardown: step 8, image 1 of 1
    • The 3.7V 950 mAh Li-Polymer battery allows for 4 hours of talk time.
    • Measuring 40 x 35 x 5.5 mm and weighing in at a scant 18 grams, the X10 Mini E10i's battery provides up to 360 hours of 3G standby time.
    • The batteries of both the iPhone 3GS and the X10 Mini E10i have capacities of about 53 mAh per gram.
  9. Sony Ericsson Xperia X10 Mini E10i Teardown: step 9, image 1 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 9, image 2 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 9, image 3 of 3
    • The 5 MP camera, battery connector, vibrator motor, and speaker are densely packed on the logic board near the top of the phone.
    • After disconnecting the touchscreen connector, the logic board can be carefully pried out of its enclosure.
  10. Sony Ericsson Xperia X10 Mini E10i Teardown: step 10, image 1 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 10, image 2 of 3 Sony Ericsson Xperia X10 Mini E10i Teardown: step 10, image 3 of 3
    • Rotate the logic board upward out of its cradle and use an iPod opening tool to disconnect the display data ribbon cable.
    • The shields covering the majority of the chips housed on the logic board protect their sensitive circuitry from electromagnetic interference.
  11. Sony Ericsson Xperia X10 Mini E10i Teardown: step 11, image 1 of 2 Sony Ericsson Xperia X10 Mini E10i Teardown: step 11, image 2 of 2
    • Big players on the board include:
    • A Qualcomm MSM7227 with 600 MHz application processing, 400 MHz modem processing, hardware accelerated 3D graphics, integrated Bluetooth 2.1 & GPS capabilities, and image/video encoding & decoding.
    • STMicroelectronics NANDCBR4N9
    • Skyworks SKY77336 GSM power amplifier module
    • Qualcomm PM7540 power management IC
    • Qualcomm RTR6285 UMTS RF transceiver with receive diversity and GPS
    • TriQuint TQM679002A WLAN Power Amplifier
  12. Sony Ericsson Xperia X10 Mini E10i Teardown: step 12, image 1 of 1
    • Sensors near the top of the board face outward from the front of the phone near the earphone opening.
    • A proximity sensor turns off the touch screen when the phone is against your face.
    • A light sensor automatically adjusts the LCD brightness for optimal viewing in any lighting condition.
  13. Sony Ericsson Xperia X10 Mini E10i Teardown: step 13, image 1 of 2 Sony Ericsson Xperia X10 Mini E10i Teardown: step 13, image 2 of 2
    • Further prying around the perimeter of the front panel assembly allows the LCD assembly to be separated from the front panel.
  14. Sony Ericsson Xperia X10 Mini E10i Teardown: step 14, image 1 of 2 Sony Ericsson Xperia X10 Mini E10i Teardown: step 14, image 2 of 2
    • The digitizer is manufactured by Synaptics, with the main touch screen controller labeled as T1021A 1 0942 AC0P876.
    • Interestingly enough, this is similar to the digitizer found in Microsoft's Kin Two.
    • A Samsung LMS255GF02 takes care of the Mini E10i's display needs.
  15. Sony Ericsson Xperia X10 Mini E10i Teardown: step 15, image 1 of 1
    • And just like that, the dark deed has been done.
    • Thanks, Sony, for keeping it simple.
    • For more information on this little guy, check out EDN's Xperia X10 Mini Preview.
    • Keep an eye on our Teardown page for the arrival of the highly anticipated iPhone 4.
    How to replace a broken SIM holder
    ephraimeh - Reply
14 Comments
he great take apart, do you need to dissemble the whole phone to replace the power button cap?
Alex - Reply
More or less. It's been a while since I took this apart, but I think you'll have to take the logic board out (work up to step 9). Luckily, this phone is really straightforward to disassemble.
Andrew Bookholt -
so you can't use BST-38 Size: (5.5 x 48 x 40 mm) battery instead that one you have on the picture (or BST-41 some sellers on Ebay say it is compatible) ???
Konstantin K - Reply
great guide, helped me replace a squashed LCD screen by working through and then going in reverse, thanks!
sgtbrom - Reply
Hi There
This is a fantastic guide, and has enabled me to get the battery out, does anyone know where on earth I can buy one of these, I have searched all the usual channels, google ebay etc, but can only find batteries for other models that look nothing like this.
Any help would be much appreciated
All the best - Trev
Trevor Woodgate - Reply
Hallo,
habe mir ein Akku gekauft bei GAME-SHOP-ONE.DE Art.139 für 9,99 € ist Original mit Rahmen.
GAME-SHOP-ONE.DE
Euskirchnerstr. 2
52351 Düren
Hoffe ich konnte dir helfen. Kannst du mir sagen wie ich das Akku mit Rahmen aus dem Gerät bekomme. Gerät habe ich schon
auseinander gebaut. Wäre toll, danke bitte Antwort an meine Mail Adresse. adler@ci01.de. DANKE.
Gruß aus Fulda
Matthias
Matthias Klueh -
its very helpfull!
do you need to dissemble the whole phone to replace the front cover of the display? is it secured to the inner case with screws
periklis manolatos - Reply
can u tell me where i can get a battery for this phone??please
Lalzamliana Ralte - Reply
I need sony xperia x10 mini
surajmaharjan123 - Reply
I need a new battery and screen fitted by others urgent
copperscottage - Reply
Signal Network is not showing. When put charging it's become too heat. And also it's decrease the battery level with in 20mins
Amithesh - Reply
The best for you, and good job
vespa66bali - Reply
hi
great job.
I want to use de display on another application.
any chance to identify the electrical 10 positions on the display flat cable
thanks
jj
juan - Reply
hi, i just wanted to ask if what was the problem if may phone does charge, but just keep on blinking red, and starts up but it won’t open..just on SE logo only?please help..thank u
Cora Corpuz Anunsacion - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 65
All Time: 473,960
