Introduction
A look inside the Samsung QLED TV Smart Remote
Samsung QLED TV Smart Remote with Voice Command via Samsung's Bixby, and WiFi Direct
To open the Samsung Smart TV Remote, flip the remote over and slide the back cover down in the direction on the indicators.
Sliding the backside on the remove toward the indicators will expose a small gap on the front side of the remote.
The exposed gap allows for easy gripping of the back cover, so that the back cover can be removed.
Removing the back cover exposes the battery compartment, and pairing instructions for the remote.
To open the remote enclosure, a Plastic Opening Tool can be use to start the separation of the enclosure seam via the large clip opening areas. Then a Spudger Tool can be used to pry open the enclosure.
Once the enclosure starts to open, gentle move along the outside of the remote enclosure seam with the Spudger Tool to release the remaining enclosure clips.
A close inspection of the tactile button side of the PCB revealed two small holes. These small holes turned out to be port openings for dual MEMS Microphones found in the remote.
Also, found during the close inspection of tactile button side of the PCB was that the two horizontal buttons on the front face of the remote are also able to contact tactile buttons above and below the tactile button they rest on, which means that the user can push down, push up, or pull down when using those buttons.
A LED was also located near one of the Microphone port holes.
Turning our attention to the backside of the PCB, we can review the components that give the remote its functionality. There are a number of discrete parts, transistors, and power supply ICs. Plus the components that were cross referenced listed below. Some parts could not be cross referenced. Leave comment if you know a part.
Universal Electronics Voice Controlled Remote Controller with WiFi Direct UE878NMEG
WiFi Chip Antenna
Infrared LED
30 Comments
Impossible to open this remote
I finally found out why my remote turns on bixby all the time, its the Vesprr wake up mic: https://us.community.samsung.com/t5/4k-8...
Samsung support say the replacement mics don't have it. Looks like this wake up technology doesn't work.
Great instructions. Some food goo got on under the click wheel, and was stuck on one side. Cleaned it up after disassembly. Ifixit is the best!!
