This teardown is not a repair guide. To repair your Samsung Intensity, use our service manual.
  1. Samsung Intensity Teardown, Samsung Intensity Teardown: step 1, image 1 of 1
    • Remove the back cover and battery
  2. Samsung Intensity Teardown: step 2, image 1 of 1
    • Remove the 8 screw that hold the back cover down.
    • Carefully pry back piece off
    • Start at the bottom and work toward the top.
  3. Samsung Intensity Teardown: step 3, image 1 of 1
    • Use the ipod opening tool to disconnect the Connector
  4. Samsung Intensity Teardown: step 4, image 1 of 2 Samsung Intensity Teardown: step 4, image 2 of 2
    • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
  5. Samsung Intensity Teardown: step 5, image 1 of 2 Samsung Intensity Teardown: step 5, image 2 of 2
    • Remove the 6 screws
    • Pry to ribbon cable assembly loose from the slider
    • Its glued on the left and right side
  6. Samsung Intensity Teardown: step 6, image 1 of 1
    • Remove the 4 screw the holds the slider to the phone assembly
    • one of the screws will be behind the hinge
    • Carefully pry slider assembly loose from display assembly
  7. Samsung Intensity Teardown: step 7, image 1 of 3 Samsung Intensity Teardown: step 7, image 2 of 3 Samsung Intensity Teardown: step 7, image 3 of 3
    • Remove the tape and pop the connectors and pull all the ribbon cables loose
    • Carefully pry the speaker loose from the case.
  8. Samsung Intensity Teardown: step 8, image 1 of 1
    • Carefully work the keyboard loose from the display assembly
    • There are a couple fragile clips that hold it in place
  9. Samsung Intensity Teardown: step 9, image 1 of 2 Samsung Intensity Teardown: step 9, image 2 of 2
    • LCD comes out pretty easily
    • Pry it from the bottom and work up the sides to release it if stuck
    • The glass can be removed with a little heat from a heat gun or blow dryer
    • Pry it out from the outside edges working around carefully
David
148 Reputation
1 Guide authored
West Georgia Technology Member of West Georgia Technology
Business
1 Member
1 Guide authored
One Comment
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 4,700
