Repair Guides
Learn how to fix just about anything with our step-by-step guides.
App
Your pocket repair helper.
FixBot
The friendly AI repair assistant.
Repairability
Learn why fixable products make sense.
Teardowns
Get a sneak peek inside the latest gadgets.
Answers Forum
Share solutions and get help from a friend.
Find Your Community
Find teams, events, and fellow fixers.
Help Out
Help make repair knowledge free and accessible for everyone.
Right to Repair
Learn about the Right to Repair movement and how to be an advocate.
Featured
Quality parts and tools backed by our lifetime guarantee.
Tools
Shop our wide selection of precision tools.
Parts
Shop parts backed by our quality guarantee.
iPhone Batteries
Batteries tested and guaranteed plus a kit with everything you need.
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Teardown
This teardown is not a repair guide. To repair your Samsung Galaxy S Advance, use our service manual.
Remove the rear cover
Remove battery
Remove the 6 screws
Use a thin tool to pry between the glass and the frame to release it
Remove the midframe
Disconnect the rear speaker connector
Disconnect the front camera and ambient light sensor connector
Disconnect the display connector
Disconnect the power button cable
Disconnect the volume buttons cable
Disconnect the white cable
Remove the rear speaker
Remove the screw, and lift the motherboard
Remove the front speaker
Disconnect the connector under the motherboard
remove the motherboard
Disconnect the rear camera connector
Remove the rear camera
Remove the front-facing camera and ambient light sensor
Lift the adhesive using heat
Disconnect the microphone
Disconnect the daughterboard
Remove vibration motor
Heat the front side to 80°C to separate the glass from the touch display
Unclip the touchscreen display from the case
Teardown complete
12,380 Reputation
39 Guides authored
Badges: 25
+22 more badges
thank u very much
gudehassan - Jun 24, 2017 Reply Share
شكرا جزيلا لك هذا ممتاز
ALFITORI - Apr 2, 2020 Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 39
All Time: 1,604
