This teardown is not a repair guide. To repair your Roborock Auto-empty Dock, use our service manual.
  1. Roborock Auto-empty Dock (Onyx): Teardown, Roborock Auto-empty Dock (Onyx): Teardown: step 1, image 1 of 1
    • Let's begin by removing its ramp. Flip it on it's head.
    • Use a PH2 screwdriver to unscrew the screws, then take the ramp off.
  2. Roborock Auto-empty Dock (Onyx): Teardown: step 2, image 1 of 2 Roborock Auto-empty Dock (Onyx): Teardown: step 2, image 2 of 2
    • Remove the marked screws.
    • Circled in red are PH2.
    • Circled in orange are PH1.
    • Then pull the bottom cover off.
  3. Roborock Auto-empty Dock (Onyx): Teardown: step 3, image 1 of 3 Roborock Auto-empty Dock (Onyx): Teardown: step 3, image 2 of 3 Roborock Auto-empty Dock (Onyx): Teardown: step 3, image 3 of 3
    • All are PH1.
    • Bend the contacts back (img3) to prevent them from shorting the PSU once you pull the assembly out.
  4. Roborock Auto-empty Dock (Onyx): Teardown: step 4, image 1 of 2 Roborock Auto-empty Dock (Onyx): Teardown: step 4, image 2 of 2
    • Remove the cables.
    • Use these images as reference when reassembling.
  5. Roborock Auto-empty Dock (Onyx): Teardown: step 5, image 1 of 3 Roborock Auto-empty Dock (Onyx): Teardown: step 5, image 2 of 3 Roborock Auto-empty Dock (Onyx): Teardown: step 5, image 3 of 3
    • Take out the PCBA+PSU assembly.
    • When taking out the assembly, make sure to disconnect the other connectors. I forgot to take pictures of these, so just take it out carefully.
    • Remove the connecting cable between the PSU and the main PBCA.
    • Unscrew the PSU.
    • Remove the PSU.
  6. Roborock Auto-empty Dock (Onyx): Teardown, Cat.: step 6, image 1 of 1
    • I caught her.
DegenFixer
5,111 Reputation
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 101
All Time: 1,007
