This teardown is not a repair guide. To repair your Computer Hardware, use our service manual.
  1. Razer Hyperflux Teardown, Removing the grip: step 1, image 1 of 1
    • Turn the mousepad over and peel off the grip with the white plastic layer.
    • The white plastic layer is glued to the device only on it's edges so if you're using the ifixit head pad you only need to put it on the edges.
    • Be sure to peel the grip + the white plastic layer. Removing just the grip and then the plastic layer will result in a very tedious process of trying to align the grip properly.
  2. Razer Hyperflux Teardown, Removing the PCB shield: step 2, image 1 of 1
    • Unscrew the 3 screws with a phillips head screwdriver
  3. Razer Hyperflux Teardown, Removing the PCB: step 3, image 1 of 3 Razer Hyperflux Teardown, Removing the PCB: step 3, image 2 of 3 Razer Hyperflux Teardown, Removing the PCB: step 3, image 3 of 3
    • Desolder the copper leads (red circle) and open the gate of the connector (blue circle)
    • You can now safely take out the pcb
    • For reassembly simply follow the steps in reverse
SgtBlade
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 45
All Time: 1,831
